Page 1 of 20 1 2 3 11 ... LastLast
Results 1 to 10 of 195
    Senior Member paisis123's Avatar
    paisis123's Computer Details
    WIN 7 PRO
    Cyperpower CUSTOM
    Gigabyte GA-870A-UD3 (Socket M2)
    AMD Phenom II X6 1055T
    8.0GB Dual-Channel DDR3
    ATI Radeon HD 6870 x2 (CROSSFIRE MODE)
    977GB GRAID SCSI Disk Device (SCSI)
    3 TB external segate drive
    3x ViewSonic VA2231w-LED
    Mechanical
    paisis123's Discipline Details
    Designer - Thermoplastic Extrusions
    Mechanical
    AutoCAD 2012
    May 2011
    Atlanta, GA
    170
    Unhappy Structural Drafting With Autocad, help with the last 3 plates
    HELLO AGAIN CAD TUTOR! (you guys are awesome)
    As the title imply i finished the first 4 plates of my project and now im starting the last 3 plates.
    In these last three plates it involves having 3 Detail drawings of certain aspects of the building and drawing them with greater detail. but i ask on what am i drawing exactly. the instructions have information randomly filled out all over the book and that makes no sense at all.
    does anyone have a picture of the last three plates to verify on what should be done? (i have looked through the forums and only found pics of plates 1-4, not 5-7)
    and i ask "what is a size description?"
    heres the booklet that im reading and trying to understand
    Structural booklet.pdf
    also note that as i wait for a reply ill try to draw these free hand on a piece of paper then wasting my time in autocad before i actually get the drawing correct.
    i thank anyone and everyone in advance.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Are you talking about plates 5, 6 and 7 (Roof details, Connection details and Foundation details respectively)?
    The instructions are fairly straightforward in what they are asking the student to detail. Basically you are going to draw some details then take portions of them and enlarge them further. These enlarged details will contain more information than could be shown at the smaller scale.
    Re: size descriptions is just what it means. If you are calling out a beam or a column you need to say what size/shape it is. For example: Steel Column W12x152, Exterior Column 22'-5" Lg.
    I would suggest using a "tag" to identify the objects in your drawings then create a table to one side listing in one column the "tag" number and in the second column the size description. A tag is a circle with a number in it and a line pointing to the object. You can find a dynamic block of this type on your tool palette on the Annotation tab.
    WIN 7 PRO
    Cyperpower CUSTOM
    Mechanical
    Mechanical
    AutoCAD 2012
    May 2011
    Atlanta, GA
    170
    thanks for the quick reply ReMark. (gives virtual cookie, topped with awesomeness)
    i have another question though.
    what exactly is "welded wire fabric" and how do u draw it? it asks me to draw it.
    also for this project its all about Zooming in onto the specified areas to show more objects? that makes it simpler. and have u found any reference pitures? i was seraching but no cigar.....
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    "Welded wire fabric is really steel wire, much like a screen, where all the points of contact where the wires touch each other have been spot welded together."
    Typically this is shown as a dashed line and everywhere there is a gap an "X" is depicted.
    Of course I have drawings of the plates but I want to see what you can come up with first. Give it your best shot. I don't like to be disappointed though. I have full faith and confidence in your ability to do it. Go...read...then do.
  5. #5
    WIN 7 PRO
    Cyperpower CUSTOM
    Mechanical
    Mechanical
    AutoCAD 2012
    May 2011
    Atlanta, GA
    170
    okay gotcha. ill attempt to do plate 5 with my limited knowledge.
    then ill post it so we can compare notes and/or adjustments as needed.
    thanks for all the help. (after these last 3 plates, I graduate! so whose hiring as of now?)
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    You've basically done some of this already when you drew the other plates.
    Who's hiring? Not sure. Look at some of the job boards or craigslist or try over at Cadalyst magazine (they have job postings).
  7. #7
    WIN 7 PRO
    Cyperpower CUSTOM
    Mechanical
    Mechanical
    AutoCAD 2012
    May 2011
    Atlanta, GA
    170
    okay i have finished plate 5. i have done what basically the book told me to do.
    Here is plate 5. I finished after 4 hours of work. (slow work, im a bad procrastinator)
    ROOF DETAILS-P5.dwg
    if u see any adjustments that need to be made please tell me. thanks in advance.
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    First question. You have a mixture of text sizes for your callouts, why? I also notice that you didn't use the tag I mentioned (a bubble with a number inside). More professional looking in my opinion.
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Detail "C" should have two areas circled that reference Details C1 and C2. Both of these details should be of a scale that make them easily readable. The detail to the right of C2 (the one you dimensioned) is so small it is barely readable. Each detail should also have the scale called out as well.
    I would also make use of hatching to distinguish important features like the cap plate for instance. BTW, wouldn't the flashing extend up and over the cap?
  10. #10
    WIN 7 PRO
    Cyperpower CUSTOM
    Mechanical
    Mechanical
    AutoCAD 2012
    May 2011
    Atlanta, GA
    170
    Excellent deduction Watson. I cant seem to scale it correctly as it changes the length of the dimensions. for example when i scale it up it makes a 1 inch line 4 inches long. is there a way to enlarge it with out affecting the scale?
    and I looked for the bubble and found was the Multileader. i don't know how to activate the bubble in the multileader settings (maybe i missed it?)
    and yes i should do the hatching to distinguish between parts. but i also have to mention that the steel plate for the cap detail is 14" long while the I beam is 13-3/4" so there not much room.
    and regarding more of the flashing, in the book it shows something like flashing , it calls it galvanized metal clap with cleats. (page 30, fig. 21-56) i tried to follow that but as you can see i have failed. (okay maybe a C+ )
  1. Need help on structural drafting project
    By Firligic in forum Student Project Questions
    Last Post: 28th Mar 2012, 05:14 pm
  2. Structural drafting project Plate 2 (penn foster)
    By ANC2008 in forum Student Project Questions
    Last Post: 13th Jul 2011, 11:47 pm
  3. Autocad structural detailing
    By Ize Buko in forum AutoCAD Beginners' Area
    Last Post: 12th Jan 2011, 11:08 pm
  4. Autocad Structural Detailing
    By pop3 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 2nd Jan 2011, 02:09 pm
  5. opening multi plates into one palite
    By MSAWIN in forum AutoCAD Beginners' Area
    Last Post: 2nd Mar 2006, 01:29 am
