Page 2 of 20 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 195
  1. #11
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    There's something amiss with your beam cross-section. It does not appear to have been drawn to the right dimensions.
    Back up. What exactly did you scale? Since you are doing everything in model space when you create your enlarged detail and try to dimension it AutoCAD assumes it is drawn to the same scale as the original. Thus, if a line was originally 3" long and you enlarged it by a factor of 4 in your detail AutoCAD will dimension it as being 12" long. Do you understand that? This is one of the reason why annotative scaling is so useful but it requires that the CAD tech make use of paper space layouts and viewports which it seems you are not utilizing. Is that correct?
    Wouldn't the steel sheathing on the outside of your column be attached vertically not horizontally?
  2. #12
    Senior Member paisis123's Avatar
    paisis123's Computer Details
    WIN 7 PRO
    Cyperpower CUSTOM
    Gigabyte GA-870A-UD3 (Socket M2)
    AMD Phenom II X6 1055T
    8.0GB Dual-Channel DDR3
    ATI Radeon HD 6870 x2 (CROSSFIRE MODE)
    977GB GRAID SCSI Disk Device (SCSI)
    3 TB external segate drive
    3x ViewSonic VA2231w-LED
    Mechanical
    paisis123's Discipline Details
    Designer - Thermoplastic Extrusions
    Mechanical
    AutoCAD 2012
    May 2011
    Atlanta, GA
    170
    yes maybe the scaling is throwing the whole drawing off. i just wanted to enlarge it with out affecting diamentions. i tried using the scale command but that didnt work. (im always confused on scale)
    and maybe i need to redo the column? the drawing instructions are vague and don't really show on what your actually trying to do.
    and thanks for the thought provoking questions. unlike other people i like being challenged!
  3. #13
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    This is what your W12x45 should look like.
  4. #14
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    My point is that when you scale something in model space and try to dimension it in model space you WILL affect the dimensions. One way to overcome this is to create a dimension style that uses a scale factor. This can be changed in your dimension style on the FIT tab where it says "Scale for dimension features" > "Use overall scale factor". In your case I am guessing this would be a scale factor of 4. This new dimension style is used only to dimension the enlarged details. Use your normal dimension style for objects that have not been scaled. Another option would be to use your normal dimension style BUT override the dimension AutoCAD uses by substituting the correct dimension.
  5. #15
    WIN 7 PRO
    Cyperpower CUSTOM
    Mechanical
    Mechanical
    AutoCAD 2012
    May 2011
    Atlanta, GA
    170
    okay thanks for the help!
    ill make the adjustments and ill start on the final 2 plates. wish me luck!
    and how do substitute the correct dimension after you enlarge it? that will the easiest course of action for me to do.
  6. #16
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Any number of ways. Try using Quick Properties, or Properties, or double-clicking on it, etc.
  7. #17
    WIN 7 PRO
    Cyperpower CUSTOM
    Mechanical
    Mechanical
    AutoCAD 2012
    May 2011
    Atlanta, GA
    170
    Default Hey ReMark check out my progress?
    I have Plate 6 if you want to look at it.
    CONNECTION DETAILS-P6.dwg
    i want you to see if the drawing is right and what kind of connection is there for Detail D1? i know how to do the connection from the girder to the Channel beam. but to the steel column to the girder is like missing. can you shed some light to this?
    and you forgot to show me your pic of plate 5!
  8. #18
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Two angle clips are used to make the connection in D1.
  9. #19
    WIN 7 PRO
    Cyperpower CUSTOM
    Mechanical
    Mechanical
    AutoCAD 2012
    May 2011
    Atlanta, GA
    170
    Default Hey ReMark check out the final plate!
    I just started my final plate (plate 7). i was reading the instructions on what to include before i start and i found something that's confusing. if you go to page 21 of the booklet and then to number 15 and 16, it asks for a 4" drain and the clearances of the 4" drain, respectably.
    Structural booklet.pdf
    How do you draw the drain? (never saw one in my booklet or in real life)
    Can you provide any details on it?
    also i have to ask about Plate E1. it looks like theirs alot info to provide, but i don't know what certain things are or there descriptions. like for example, what is an anchor bolt? how do you draw it? etc.
    any answers or rough drawings are appreciated!
  10. #20
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    You can find images of roof drains on the Internet via Google.
    Anchor bolts are used to bolt columns into concrete slabs. Draw the bolt, washer and hex nut. Depending on the view (plan or elevation) each part of the anchor bolt will look different.
  1. Need help on structural drafting project
    By Firligic in forum Student Project Questions
    Last Post: 28th Mar 2012, 05:14 pm
  2. Structural drafting project Plate 2 (penn foster)
    By ANC2008 in forum Student Project Questions
    Last Post: 13th Jul 2011, 11:47 pm
  3. Autocad structural detailing
    By Ize Buko in forum AutoCAD Beginners' Area
    Last Post: 12th Jan 2011, 11:08 pm
  4. Autocad Structural Detailing
    By pop3 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 2nd Jan 2011, 02:09 pm
  5. opening multi plates into one palite
    By MSAWIN in forum AutoCAD Beginners' Area
    Last Post: 2nd Mar 2006, 01:29 am
