"You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
snap.dwg
Attached is a blank file with 2 layout tabs, each layout has one view port.
Model Space; Snap is turned off
Layout 1; Snap is turned off when you are in paper space
Snap is turned on when you go into the view port
Layout 2; Snap is turned on when you are in paper space.
Snap is turned off when you go into the view port.
I am beginning to think that there is no system variable or something that I can change to turn it off all together. I think my only options are going to be; change the snap setting to a really small number in the acaddoc.lsp (thanks rkent), or write a progam that will go into the drawing and set snapmode to 0 in every layout and viewport.
