Results 1 to 8 of 8
    Junior Member
    Map 3D 2011
    Nov 2011
    13
    Default Problem with map3d layout
    Hey,
    First of all, thanks in advance for who actually takes time to read and answer. I cant seem to solve my problem. I have added raster image (.tiff extension), .shp extension and created surface from .shp on top of it. I created a surface and from the surface i generated contour lines. Contour line thicknesses are all set in normal numbers. The problem seems to be, that in layout view, at first the lines appear normal. Problem arises as soon as i have changed the paper size to either A4/3. Contour lines seem to be seriously out of scale and appear way too large. As large as the whole screen is basically covered in fat lines. I am using map3D 2011.
    Again, thanks in advance, who takes time to answer.
    Best regards,
    Henri Kersna
    Super Member Murph_map's Avatar
    Murph_map's Computer Details
    XP,Visa, Win7
    HP something or other and the laptop is an HP too
    2 gigs or 6 gigs in Laptop
    Utilities
    Murph_map's Discipline Details
    Boats and campers renting and repairs
    Utilities
    GIS and Map making.
    Map 3D 2011
    Feb 2011
    TN or KY depends if I'm at work or home.
    627
    I take it you are using Data Connect to bring in the shp file and create the contours with. After you set up the viewport on the layout try to refresh the map in the display manager, a right click in a open are on the display manger and select UPDATE. Another thing is you may need to create a scale range in the style editor for the contours to display as you need for that scaled viewport.
    Murph
    Need a boat or camper for the weekend?
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,203
    I have moved this to the MAP3D Forum.
    Junior Member
    Map 3D 2011
    Nov 2011
    13
    Regenerating the layout view and refreshing the contour layer doesent seem to work. I also cant find the actual place, where i could actually change the range of contour lines and labels. Does anyone have any other ideas or can perhaps guide me step-by-step to a option, where i can actually change the scale range for the contours?
    I have also added a picture to clarify the situation.
    PS I do remember having this kind of blob-situation in Civil3d also, but on those occasions just a random refresh or regeneration worked just fine.
    Thanks in advance,
    Henri
  5. #5
    XP,Visa, Win7
    Utilities
    Utilities
    GIS and Map making.
    Map 3D 2011
    Feb 2011
    627
    You create a new scale range in the Style editor, the palette thats in your screen capture, in the top half. Change the From & To to fit your scale range then in the bottom half set the style you want them to dispaly.
    As for the Paper Space layout display, I have better luck using model space to create the view/display as needed then export that map to AutoCAD DWG format, then create a layout from that exportd dwg.
    Murph
  6. #6
    Junior Member
    Map 3D 2011
    Nov 2011
    13
    Well, i am stupid:/ The style change was actually my initial thought i tried, but i missed something really basic. The style change helped. Anyways, again, thanks alot for your help and patience.
  7. #7
    Junior Member
    Map 3D 2011
    Nov 2011
    13
    I do have another issues with the whole scale issues. The elevation labelling acts weird. I change the size from the feature label settings, it acts (size decrease) normal to a certain size, but from one point it basically changes to a line, as if it was turned 90 degrees vertically. Any ideas?
    Added 2 pictures for the explanation:
  8. #8
    XP,Visa, Win7
    Utilities
    Utilities
    GIS and Map making.
    Map 3D 2011
    Feb 2011
    627
    Do not use the Device Space for the size content, use Map space and size the label based on the map units/scale. When using PS Layouts the device space has issues that are hard to understand the scaleing/zooming levels.
    Murph
  1. Replies: 2
    Last Post: 5th Aug 2010, 07:24 pm
  2. Images in Map3d
    By choward_01 in forum Map 3D
    Last Post: 9th Jun 2008, 09:44 am
  3. Another viewport question Map3D
    By SR1 in forum AutoCAD General
    Last Post: 29th Feb 2008, 10:16 am
  4. PC Specs For Map3D
    By grocket007 in forum AutoCAD Drawing Management & Output
    Last Post: 29th Dec 2006, 08:26 pm
  5. Map3D, MapGuide for GIS
    By kaymac in forum AutoCAD General
    Last Post: 23rd Sep 2006, 02:03 am
