Results 1 to 3 of 3
    Forum Newbie
    2bagz's Computer Details
    Windows 7 x64
    Dell Precision
    Intel Xeon
    6Gb
    AutoCAD 2012
    Nov 2008
    Ontario, Canada
    5
    Default Difficulties with truetype fonts when plotting
    I am currently working with some true type fonts, and having the following results occur:
    I have a Mtext object, Text style named Tahoma.
    there are 5 lines to it. The formatting of the first line is bolded, not the remainder.
    When I plot using DWG to PDF, all of the other Mtext objects and all lines of the original are bolded.
    Print preview does not show this, everything looks fine on the drawing screen, it only appears on the PDF.
    As a workaround, I have created a Tahoma - Bold Text Style for the original object, and formatted the secod thru last line as non-bold, and this seems to work. This has only begun to occur since switching to AutoCAD 2012.
    I can work around, however it is quite annoying to have to do seeing as many legacy drawings will be re-used, and I would have to make this change to all of them (including the layouts used in those files)
    Todd
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,769
    Use a third party pdf plotting program. I use the free download Autodesk Trueview. Advantages are that it is used identically to AutoCAD for plotting, and it can convert drawings to be compatible with earlier releases if you need it. Also, the resulting trueview pdf output file is many times smaller in file size than what AutoCAD puts out. Aparently AutoCAD records virtually all of the overhead data from the dwg to the pdf, and TrueView does not.
    AutoCAD seems to have a continuous problem plotting pdf files. I've been experiencing the same sort of issues since the pdf output facility was added to AutoCAD. Trueview cured them all for me.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Super Member Tankman's Avatar
    Tankman's Computer Details
    XP Pro SP3
    IBM T60 Thinkpad™
    36" LCD Monitor/TV, 14" Thinkpad™ T60
    AutoCAD 2007
    Mar 2008
    Eastern PA, USA
    1,796
    I've experienced the same results using TrueView. TrueView also comes in handy for those who don't
    have AutoCAD for viewing *.dxf or *.dwg files. TrueView is a freebie too.
    Tankman
    "When the well is dry, we know the worth of water." Ben Franklin ~ 1746
  1. Converting shape fonts (.shx) to TrueType (.ttf)
    By Blam in forum AutoCAD General
    Last Post: 6th Apr 2011, 10:46 pm
  2. Typing Special Characters in Truetype fonts
    By MatthewDS in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Apr 2010, 03:44 am
  3. Converting .shtx fonts to TrueType for 2010 ACAD and Revit
    By Cadfused in forum AutoCAD General
    Last Post: 24th Feb 2010, 12:05 am
  4. Truetype fonts do not display in clipped viewport
    By profcad in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 3rd Mar 2008, 03:54 pm
  5. TrueType fonts appear BOLD
    By khairulfikri in forum AutoCAD Drawing Management & Output
    Last Post: 6th Oct 2005, 05:34 pm
