Results 1 to 6 of 6
Thread: View of Drawing
    Junior Member
    not specified
    Mar 2006
    US Virgin Islands
    18
    Default View of Drawing
    I have two different drawings on the same space and was working on one of the drawings in zoom window. However when I try to see both drawings by zooming all, I get skewed objects in the screen.
    Please advise how I could get both drawings to show in the window.
    Best Regards,
    EKMoorhead
    Super Member JBullseye74's Avatar
    Construction
    JBullseye74's Discipline Details
    Facade Designer
    Construction
    AutoCAD 2013
    Feb 2006
    UK North West
    768
    Interesting - try this
    Type - CHANGE - Select Objects - ALL
    Return - Properties - Elevation - If this says varies then reset to 0
    Now zoom all and the drawings should be on the same elevation.
    Let me know if this works. :-)
    AutoCAD 2010
    '"Accept that some days you're the pigeon, and some days you're the statue."
    Junior Member
    not specified
    Mar 2006
    US Virgin Islands
    18
    Default Drawing view
    Nothing worked, in fact when I typed all it said that 4 were not in current space.
    Super Moderator Lazer's Avatar
    Lazer's Computer Details
    Windows 7
    HP xw 4600 Workstation
    Intel Core2 Duo, 3 Gig
    8GB
    NVIDEA Quadro FX 1700
    1TB
    Portable TB drive
    Samsung SyncMaster 226
    Inventor 2013
    Aug 2005
    Northants, England
    1,565
    Default Re: View of Drawing
    Quote Originally Posted by engineer1
    Best Regards,
    EKMoorhead
    Your not typing zoom all in paperspace are you. sorry but I had to ask!
    USING AUTOCAD 2013 AND INVENTOR 2013, ALIAS 2013.
    If in doubt scale and don't ask!
  5. #5
    Junior Member
    not specified
    Mar 2006
    US Virgin Islands
    18
    Default Views
    I was using the first view that I did my drawings in which was model. I do not know how to use the other two layouts: Layout 1 and Layout 2.
  6. #6
    Full Member
    not specified
    Apr 2006
    27
    [quote="JIMMY"]
    I'm having the same problem
    I finally got the UCS & view aligned to work on a long site section
    but now the area is too big to work on - I tried to switch to 2 horizontal viewports (Model Space) but I can't get them aligned to start making the construction lines for the section.
    After following your suggestion, after I select All objects, it says "4 were not in the current view" i hit Enter. Then it prompts me for the Properties, I hit enter, but then it wants "Specify new block insertion point" ?! I can't even enter a value or accept the one it's offering <90> it just keeps responding "No Change"
    Help????
    thanks-TC
    In Case I forget- I'm using AutoCAD 2004!
    Thanks always.
