Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
  1. #11
    Senior Member
    Civil
    Hippe013's Discipline Details
    Survey Crew Chief / Civil Designer
    Civil
    Land Survey / Civil Engineering
    Civil 3D 2017
    Feb 2010
    North Dakota
    385
    Ok... So C:geoico isn't working quite right yet.... ((Hrm... ) worked last night)
    but C:geo8 is working correctly
    ok all is working it was just a snaps issue
  2. #12
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Thank you for sharing your lisp routine with us. I'm sure someone will find it handy. We have requests for help with geodesic domes a couple of times a year.
  3. #13
    Senior Member
    Civil
    Civil
    Civil 3D 2017
    Feb 2010
    North Dakota
    385
    You're welcome! This was a really fun one to research! Helped me understand the whole recursive function thingy!
  4. #14
    Super Member marko_ribar's Avatar
    marko_ribar's Computer Details
    Windows 7 Ultimate X64
    Intel quad core CPU 4x2.66GHz, 8GB RAM
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    NVIDIA GeForce 6600 GT
    250 GB
    500 GB
    Samsung 17''
    Architectural
    marko_ribar's Discipline Details
    Architecture, project designer, project visualisation
    Architectural
    space design - modeling and animations
    AutoCAD 2014
    Feb 2010
    Belgrade, Serbia, Europe
    1,295
    Yes, Hippe's code is good, but I had time to make some mods. to make the code even better (using of (ssget "_X") in DWG full with other entities is bad in my opinion)...
    Code:
    (defun negval ( pnt )
      (mapcar '- pnt)
    (defun vec->pnt ( strt norm mag )
      (mapcar '+ strt (mapcar '(lambda ( x ) (* mag x)) norm))
    ;;;(vec->pnt '(0 0 0) '(1 0 0) 1)
    (defun normal ( p )
      (mapcar '(lambda ( i ) (/ i (sqrt (apply '+ (mapcar '* p p))))) p)
    (defun face ( A B C n / ab ac bc )
      (if (> n 0)
          (setq AB (normal (mapcar '+ A B)))
          (setq AC (normal (mapcar '+ A C)))
          (setq BC (normal (mapcar '+ B C)))
          (setq n (1- n))
          (face A AB AC n)
          (face B AB BC n)
          (face C AC BC n)
          (face AB AC BC n)
          (vlax-invoke-method *ms* 'add3dface
            (vlax-3d-point (vec->pnt ctr A rad))
            (vlax-3d-point (vec->pnt ctr B rad))
            (vlax-3d-point (vec->pnt ctr C rad))
            (vlax-3d-point (vec->pnt ctr (negval A) rad))
            (vlax-3d-point (vec->pnt ctr (negval B) rad))
            (vlax-3d-point (vec->pnt ctr (negval C) rad))
    (defun c:geo8 ( / *ms* f ctr rad pntA pntB pntC el ss )
      (vl-load-com)
      (setq *ms* (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)))))
      (if (> 0 (setq f (getint "\nEnter nth Order: ")))
        (setq f (- f))
      (setq ctr (getpoint "\nSelect Center of Sphere: "))
      (initget 7)
      (setq rad (getdist ctr "\nEnter Radius: "))
      (setq pntA '(0 0 1))
      (setq pntB '(0 1 0))
      (setq pntC '(1 0 0))
      (if (entlast)
        (setq el (entlast))
      (if el
        (while (entnext el)
          (setq el (entnext el))
      (setq ss (ssadd))
      (face pntA pntB pntC f)
      (if (not el)
          (setq el (entnext))
          (ssadd el ss)
          (while (setq el (entnext el))
            (ssadd el ss)
          (ssadd el ss)
      (command "_.ARRAY" ss "" "_P" "_non" ctr 4 "" "")
    (defun c:geoico ( / *ms* f ctr rad x y z u v p0 p1 p2 p3 el ss )
      (vl-load-com)
        (setq f (- f))
      (initget 7)
      (setq x (sqrt (/ (+ 5.0 (sqrt 5.0)) 10.0))) ;these formulas calculate the
      (setq y (sqrt (/ (- 3.0 (sqrt 5.0)) 10.0))) ;vertices of two icosahedral
      (setq z (sqrt 0.2))                ;faces, the first having
      (setq u (sqrt (/ (- 5.0 (sqrt 5.0)) 10.0))) ;vertices (0 0 1), (x y z),
      (setq v (- (* x x)))               ;(u v z), and the second with
      (setq p0 (list 0.0 0.0 1.0))       ;vertices (x y z), (u v z),
      (setq p1 (list x y z))             ;(x -y -z).
      (setq p2 (list u v z))
      (setq p3 (list x (- y) (- z)))
      (if (entlast)
        (setq el (entlast))
      (if el
        (while (entnext el)
      (setq ss (ssadd))
      (face p0 p1 p2 f)
      (face p1 p2 p3 f)
      (if (not el)
          (setq el (entnext))
          (ssadd el ss)
            (ssadd el ss)
          (ssadd el ss)
      (command "_.ARRAY" ss "" "_P" "_non" ctr 5 "" "")
    Regards, M.R.
    Marko Ribar, d.i.a. (graduated engineer of architecture)
    M.R. on YouTube
  5. #15
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Since my sole purpose for testing was to check that Hippie013's lisp routine worked I started with a new drawing thus there were no other entities to be concerned about. None-the-less, thanks for the improvements. I'm sure someone, someday, will be thankful for the revised version.
  6. #16
    Senior Member
    Civil
    Civil
    Civil 3D 2017
    Feb 2010
    North Dakota
    385
    Quote Originally Posted by marko_ribar View Post
    Marko,
    I appreciate the update to the code, and Yes, using (ssget "_X") was a poor choice. It is interesting to see my code from 5+ years ago and how different I would write the same code today. I would like to run tests with this code up against an updated version translated into vb.net and see if there is a significant performance change. Maybe if I find time I'll give the translation a go.
    Till then, Cheers!
  7. #17
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    250 GB
    500 GB
    Samsung 17''
    Architectural
    Architectural
    AutoCAD 2014
    Feb 2010
    1,295
    Hi Hippe, according to 3ds MAX software, it seems that there is also tetrahedral one, but it's ugly... Nevertheless I've coded according to your sub functions and for this one... Also I've rotated main points along X axis, so that now when geodesic sphere (tetrahedral) is created, you can just step in front view and slice it to hemisphere (dome)...
    Code:
      (mapcar '- pnt)
    (defun normal ( p )
      (if (> n 0)
          (setq n (1- n))
          (face A AB AC n)
          (face B AB BC n)
          (face C AC BC n)
          (face AB AC BC n)
    (defun face-nomirror ( A B C n / ab ac bc )
      (if (> n 0)
          (setq n (1- n))
          (face-nomirror A AB AC n)
          (face-nomirror B AB BC n)
          (face-nomirror C AC BC n)
          (face-nomirror AB AC BC n)
    (defun c:geo4-tetra ( / *ms* f ctr rad p0 p1 p2 p3 )
      (vl-load-com)
        (setq f (- f))
      (initget 7)
      (setq p0 (normal (list 0.0 0.0 (/ (sqrt 3.0) 2.0))))
      (setq p1 (normal (list 0.0 (/ (sqrt 2.0) (sqrt 3.0)) (/ (sqrt 3.0) (- 6.0)))))
      (setq p2 (normal (list (/ (sqrt 2.0) (- 2.0)) (/ (- 1.0) (sqrt 6.0)) (/ (sqrt 3.0) (- 6.0)))))
      (setq p3 (normal (list (/ (sqrt 2.0) 2.0) (/ (- 1.0) (sqrt 6.0)) (/ (sqrt 3.0) (- 6.0)))))
      (setq p0 (trans (polar '(0.0 0.0 0.0) (+ (* 0.5 pi) (atan (/ (sqrt 6.0) 3.0) (/ (sqrt 3.0) 3.0))) 1.0) '(1.0 0.0 0.0) 0))
      (setq p1 (trans (polar '(0.0 0.0 0.0) (+ (- (atan (/ (sqrt 3.0) 6.0) (/ (sqrt 2.0) (sqrt 3.0)))) (atan (/ (sqrt 6.0) 3.0) (/ (sqrt 3.0) 3.0))) 1.0) '(1.0 0.0 0.0) 0))
      (setq p2 (trans (polar (list 0.0 0.0 (/ (sqrt 2.0) (- 2.0))) (+ (+ pi (atan (/ (sqrt 3.0) 6.0) (/ 1.0 (sqrt 6.0)))) (atan (/ (sqrt 6.0) 3.0) (/ (sqrt 3.0) 3.0))) (/ (sqrt 3.0) 3.0)) '(1.0 0.0 0.0) 0))
      (setq p3 (trans (polar (list 0.0 0.0 (/ (sqrt 2.0) 2.0)) (+ (+ pi (atan (/ (sqrt 3.0) 6.0) (/ 1.0 (sqrt 6.0)))) (atan (/ (sqrt 6.0) 3.0) (/ (sqrt 3.0) 3.0))) (/ (sqrt 3.0) 3.0)) '(1.0 0.0 0.0) 0))
      (face-nomirror p0 p1 p2 f)
      (face-nomirror p1 p2 p3 f)
      (face-nomirror p2 p3 p0 f)
      (face-nomirror p0 p1 p3 f)
    (defun c:geo8-octa ( / *ms* f ctr rad pntA pntB pntC el ss )
      (vl-load-com)
        (setq f (- f))
      (initget 7)
      (if (entlast)
        (setq el (entlast))
      (if el
        (while (entnext el)
      (setq ss (ssadd))
      (if (not el)
          (setq el (entnext))
          (ssadd el ss)
            (ssadd el ss)
          (ssadd el ss)
    (defun c:geo20-icosa ( / *ms* f ctr rad x y z u v p0 p1 p2 p3 el ss )
      (vl-load-com)
        (setq f (- f))
      (initget 7)
      (setq z (sqrt 0.2))
      (if (entlast)
        (setq el (entlast))
      (if el
        (while (entnext el)
      (setq ss (ssadd))
      (face p0 p1 p2 f)
      (face p1 p2 p3 f)
      (if (not el)
          (setq el (entnext))
          (ssadd el ss)
            (ssadd el ss)
          (ssadd el ss)
    Here is complete code, but I've also noticed that when tetrahedral geodesic sphere is created, some faces are inside it - those just around main vertices of tetrahedron... [EDIT : I think I've corrected this issue - sub function wasn't recursive to itself but it called (face) instead (face-nomirror)]
    Regards, and I hope that my intervention is also useful...
    M.R.
    M.R. on YouTube
  1. easy way to make a geodesic dome
    By 64lesabre in forum AutoCAD 3D Modelling & Rendering
    Last Post: 10th Aug 2012, 11:38 am
  2. Replies: 0
    Last Post: 1st Sep 2011, 04:20 am
  3. Need Help With Geodesic Dome
    By brian nguyen in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st May 2010, 06:28 pm
  4. geodesic dome
    By sagaro in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Jan 2010, 07:16 am
  5. skylight detail for a geodesic dome
    By micks_27986 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 10th Feb 2009, 03:07 pm
