+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Full Member
    Using
    AutoCAD LT 2012
    Join Date
    Aug 2011
    Posts
    36
    Unhappy Brick and mortar hatching nightmare
    Hi I am trying to create a specific hatch for bricks and mortar. I have no problem creating the standard brick hatch but when I try to put mortar around the bricks that is when I get unstuck!
    my horizontal lines and spaces appear to be okay but my vertical lines are all over the place, very confusing!!
    I have attached my workings (have not yet got to the 4th line of code though!)if anyone can see anything that may help I would very much appreciate it!!!!
  2. #2
    Forum Deity
    Using
    AutoCAD 2002
    Join Date
    Sep 2006
    Location
    East Sussex, U.K.
    Posts
    2,965
    Default
    I think you had the repeat spacing and the dash space not correct. This seems to work.
    Code:
    *MYBRICK, Custom brick and mortar
    0, 0,0, 110,70, 215,-5
    0, 0,65, 110,70, 215,-5
    90, 0,0, 70,110, 65,-75
    90, 215,0, 70,110, 65,-75
    If you want to use it as a standalone file, then choose a shorter heading, which MUST be the same as the name of the file. If you add it to acad.pat or acadiso.pat, then you might loose it when you update.
  3. #3
    Full Member
    Using
    AutoCAD LT 2012
    Join Date
    Aug 2011
    Posts
    36
    Default
    Hi
    Thanks for that, I think I sorted out - I seemed to have doubled up on some of my vertical lines??!! but it works now!!
Similar Threads
  1. How would you do a good looking brick design on my new home?
    By buildman in forum AutoCAD Beginners' Area
    Last Post: 29th Aug 2011, 03:30 pm
  2. forced perspective brick - Autocd
    By Dburch in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 18th Aug 2011, 08:27 am
  3. Dynamic block - brick heads
    By mattspur in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jul 2010, 01:14 pm
  4. Brick Arches
    By kmapro in forum AutoCAD Drawing Management & Output
    Last Post: 18th Jul 2007, 04:37 pm
  5. Brick Hatch Pattern in Detail Component Manager
    By Shrek in forum AutoCAD Drawing Management & Output
    Last Post: 29th Mar 2007, 03:18 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
