Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Senior Member ketxu's Avatar
    ketxu's Computer Details
    Sorry, my English not well :(
    AutoCAD 2007
    Sep 2010
    169
    Default [Help] How to get mirror point by Trans ?
    Good day all of you.
    I'm trying to write a function to get mirror point (Return) of a point (P) through P1 & P2. Let me show Picture to help my poor English :
    How can i do it with Trans function ^^
    Thank you very much
    Forum Deity Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draftsman
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,631
    This ... ?
    Code:
    (if
      (and
        (setq p1 (getpoint "\n First Point :"))
        (setq p2 (getpoint p1 "\n Second Point :"))
        (setq p (getpoint "\n Third Point :"))
         (setq return (polar p (+ (angle p1 p2) (/ pi 2.)) (distance p1 p2)))
         (entmake (list '(0 . "LINE") (cons 10 p1) (cons 11 p2)))
         (entmake (list '(0 . "LINE") (cons 10 p) (cons 11 return)))
    - When aim is being settled in my mind , I have to reach it and get it in hand whatever it costs and wherever it is and will never give up . Tharwat said
    Senior Member marko_ribar's Avatar
    marko_ribar's Computer Details
    Windows 7 Ultimate X64
    Intel quad core CPU 4x2.66GHz, 8GB RAM
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    NVIDIA GeForce 6600 GT
    250 GB
    500 GB
    Samsung 17''
    Architectural
    marko_ribar's Discipline Details
    Architecture, project designer, project visualisation
    Architectural
    space design - modeling and animations
    AutoCAD 2012
    Feb 2010
    Belgrade, Serbia, Europe
    338
    Tharwat, you didn't calculate distance correctly... Try this :
    Code:
    (defun nor ( v )
      (polar '(0 0 0) (+ (angle '(0 0 0) v) (/ PI 2)) 1.0)
    (defun pld ( a b p / ab nab pp ppp d )
      (setq ab (mapcar '- b a))
      (setq nab (nor ab))
      (setq pp (mapcar '+ p nab))
      (setq ppp (inters a b p pp nil))
      (setq d (distance p ppp))
      d
    (defun c:ptmirror ( / p1 p2 p return )
      (if
        (and
           (setq return (polar p (- (angle p1 p2) (/ pi 2.)) (* 2. (pld p1 p2 p))))
           (entmake (list '(0 . "LINE") (cons 10 (trans p1 1 0)) (cons 11 (trans p2 1 0))))
           (entmake (list '(0 . "LINE") (cons 10 (trans p 1 0)) (cons 11 (trans return 1 0))))
    M.R.
    Note : Your third picked point must be on left side from drawn line - first point to second from bottom to top. Just like shown on picture only p1 and p2 should have opposite positions...
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    250 GB
    500 GB
    Samsung 17''
    Architectural
    Architectural
    AutoCAD 2012
    Feb 2010
    338
    Here is another one using my sub functions (transptucs) & (transptwcs)... Although all is based on trans function, I still had to use subfunction int-line-plane to obtain closest point to line from your point... Maybe there is even better and easier way, but this is also OK - works in 3D and code is in Vanilla ALISP :
    Code:
    ; transptucs & transptwcs by M.R. (Marko Ribar, d.i.a.)
    ; arguments :
    ; pt - point to be transformed from WCS to imaginary UCS with transptucs and from imaginary UCS to WCS with transptwcs
    ; pt1 - origin of imaginary UCS
    ; pt2 - point to define X axis of imaginary UCS (vector pt1-pt2 represents X axis)
    ; pt3 - point to define Y axis of imaginary UCS (vector pt1-pt3 represents Y axis)
    ; important note : angle between X and Y axises of imaginary UCS must always be 90 degree for correct transformation calculation
    ;; Vector Cross Product - Lee Mac
    ;; Args: u,v - vectors in R^3
    (defun v^v ( u v )
      (list
        (- (* (cadr u) (caddr v)) (* (cadr v) (caddr u)))
        (- (* (car  v) (caddr u)) (* (car  u) (caddr v)))
        (- (* (car  u) (cadr  v)) (* (car  v) (cadr  u)))
    ;; Unit Vector - Lee Mac
    ;; Args: v - vector in R^n
    (defun unit ( v )
      ( (lambda ( n ) (if (equal 0.0 n 1e-14) nil (vxs v (/ 1.0 n)))) (norm v))
    ;; Vector x Scalar - Lee Mac
    ;; Args: v - vector in R^n, s - real scalar
    (defun vxs ( v s )
      (mapcar '(lambda ( n ) (* n s)) v)
    ;; Vector Norm - Lee Mac
    (defun norm ( v )
      (sqrt (apply '+ (mapcar '* v v)))
    (defun transptucs ( pt pt1 pt2 pt3 / u v n uu vv ptt pt1u ptx pty ptz )
      (setq u (mapcar '- pt2 pt1))
      (setq v (mapcar '- pt3 pt1))
      (setq n (unit (v^v u v)))
      (setq uu (unit u))
      (setq vv (unit v))
      (setq ptt (trans pt 0 n))
      (setq pt1u (trans pt1 0 n))
      (setq ptz (caddr (mapcar '- ptt pt1u)))
      (setq ptt (trans pt 0 uu))
      (setq pt1u (trans pt1 0 uu))
      (setq ptx (caddr (mapcar '- ptt pt1u)))
      (setq ptt (trans pt 0 vv))
      (setq pt1u (trans pt1 0 vv))
      (setq pty (caddr (mapcar '- ptt pt1u)))
      (list ptx pty ptz)
    (defun transptwcs ( pt pt1 pt2 pt3 / pt1n pt2n pt3n )
      (setq pt1n (transptucs '(0.0 0.0 0.0) pt1 pt2 pt3))
      (setq pt2n (transptucs '(1.0 0.0 0.0) pt1 pt2 pt3))
      (setq pt3n (transptucs '(0.0 1.0 0.0) pt1 pt2 pt3))
      (transptucs pt pt1n pt2n pt3n)
    (defun int-line-plane ( pt1w pt2w pt3w ptl1w ptl2w / pt1w pt2w pt3w ptl1w ptl2w u v n ptl1n ptl2n pt1n pt4l1n pt4l2n pt4l1w pt4l2w ppw ppu )
      (if (and pt1w pt2w pt3w ptl1w ptl2w)
            (setq u (mapcar '- pt2w pt1w))
            (setq v (mapcar '- pt3w pt1w))
            (setq n (unit (V^V u v)))
            (setq ptl1n (trans ptl1w 0 n))
            (setq ptl2n (trans ptl2w 0 n))
            (setq pt1n (trans pt1w 0 n))
            (setq pt4l1n (list (car ptl1n) (cadr ptl1n) (caddr pt1n)))
            (setq pt4l2n (list (car ptl2n) (cadr ptl2n) (caddr pt1n)))
            (setq pt4l1w (trans pt4l1n n 0))
            (setq pt4l2w (trans pt4l2n n 0))
            (setq ppw (inters ptl1w ptl2w pt4l1w pt4l2w nil))
            (setq ppu (trans ppw 0 1))
      ppw
    (defun c:ptmirror ( / p1 p2 p po pu pret return )
      (if
        (and
          (setq p1 (getpoint "\n First Point on line : "))
          (setq p2 (getpoint p1 "\n Second Point on line : "))
          (setq p (getpoint "\n Third Point at dist from line : "))
          (setq p1 (trans p1 1 0))
          (setq p2 (trans p2 1 0))
          (setq p (trans p 1 0))
          (setq pp (trans p 0 (mapcar '- p1 p2)))
          (setq px (trans (mapcar '+ pp '(1.0 0.0 0.0)) (mapcar '- p1 p2) 0))
          (setq py (trans (mapcar '+ pp '(0.0 1.0 0.0)) (mapcar '- p1 p2) 0))
          (setq po (int-line-plane p px py p1 p2))
          (setq pu (transptucs p po p p2))
          (setq pret (list (- (car pu)) (cadr pu) (caddr pu)))
          (setq return (transptwcs pret po p p2))
    M.R.
  5. #5
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows XP
    Construction
    pBe's Discipline Details
    Construction
    Camp Construction planning and details
    AutoCAD 2009
    Apr 2010
    2,106
    Code:
    (Defun  c:test (/ p1 p2 p return )
      (if (not (member "geomcal.arx" (arx)))
        (arxload "geomcal")
      (if (and
          (setq
            return
             (polar
               p
               (+ (angle p1 p2)
                  (if (> (c:cal "ang(p,p1,p2)") 180)
                    (/ pi 2.)
                    4.71238898
               (* (distance
                    p
                    (vlax-curve-getClosestPointTo
                      (vlax-ename->vla-object (entlast))
                      p
                  2.0
  6. #6
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,743
    I would first refer you to my Matrix Transformation functions, which will transform an object or point list.
    However, since you specifically asked:
    Quote Originally Posted by ketxu View Post
    Consider the following function:
    Code:
    ;; Reflect  -  Lee Mac
    ;; Returns the point obtained by reflecting 'pt' in the axis defined by points p1 & p2.
    (defun Reflect ( pt p1 p2 / nm )
        (setq nm (mapcar '- p1 p2)
              p1 (trans p1 0 nm)
              pt (trans pt 0 nm)
        (trans (cons (- (+ (car p1) (car p1)) (car pt)) (cdr pt)) nm 0)
    Note however, that since the trans function uses the Arbitrary Axis Algorithm to construct a Coordinate Frame from a supplied Normal Vector, the above function will return unexpected results if the UCS plane is not parallel to the WCS plane.
    Lee Mac Programming
    Just another Swamper
  7. #7
    Windows XP
    Construction
    Construction
    AutoCAD 2009
    Apr 2010
    2,106
    Quote Originally Posted by Lee Mac View Post
    is that what he meant by trans? silly me.. i jumped in without reading the first post
    Nice Lee
  8. #8
    AutoCAD 2007
    Sep 2010
    169
    Thanks all ^^. Lee's code is what i'm looking for, but i've study more thing in all code ^^
    @Lee : so i think right, trans is shoter (i work all in 2D ^^). Thank you for your link and informatioin
  9. #9
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,743
    You're welcome Ketxu - if you have any questions about the code, just ask
    Lee Mac Programming
  10. #10
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    250 GB
    500 GB
    Samsung 17''
    Architectural
    Architectural
    AutoCAD 2012
    Feb 2010
    338
    Yes, Lee's code is surely what you're looking for... But I suggest you that you nevertheless use code that operates in 3D... Here are 2 simple examples... Much shorter than my one with transptucs and transptwcs functions... Again, Lee's sub function LM:Collinear-p is involved :
    Code:
    ;; Collinear-p - Lee Mac
    ;; Returns T if p1,p2,p3 are collinear
    (defun LM:Collinear-p ( p1 p2 p3 )
        (lambda ( a b c )
          (or
            (equal (+ a b) c 1e-8)
            (equal (+ b c) a 1e-8)
            (equal (+ c a) b 1e-8)
        (distance p1 p2) (distance p2 p3) (distance p1 p3)
    (defun nor ( v )
      (setq nab (nor ab))
      d
    (defun c:ptmirror ( / pt1 pt2 pt pt1w pt2w ptw d pt3 pt4 )
      (if (setq pt1 (getpoint "\nFirst point on line : ")
                pt2 (getpoint "\nSecond point on line : " pt1)
                pt  (getpoint "\nPoint at dist from line : ")
            (setq pt1w (trans pt1 1 0)
                  pt2w (trans pt2 1 0)
                  ptw  (trans pt 1 0)
            (vl-cmdf "_.UCS" "3p" pt pt1 pt2)
            (setq pt1 (trans pt1w 0 1)
                  pt2 (trans pt2w 0 1)
                  pt  (trans ptw 0 1)
            (setq d (pld pt1 pt2 pt))
            (setq pt3 (polar pt (+ (angle pt1 pt2) (/ pi 2.0)) d))
            (if (null (LM:Collinear-p pt1 pt2 pt3))
              (setq pt3 (polar pt (- (angle pt1 pt2) (/ pi 2.0)) d))
            (setq pt4 (polar pt3 (angle pt pt3) d))
            (entmakex (list '(0 . "LINE") (cons 10 pt1w) (cons 11 pt2w)))
            (entmakex (list '(0 . "LINE") (cons 10 ptw) (cons 11 (trans pt4 1 0))))
            (vl-cmdf "_.UCS" "p")
    And here is addition - c:projptonline
    Code:
        (lambda ( a b c )
          (or
    (defun nor ( v )
      (setq nab (nor ab))
      d
    (defun c:projptonline ( / pt1 pt2 pt pt1w pt2w ptw d pt3 )
                  ptw  (trans pt 1 0)
                  pt  (trans ptw 0 1)
            (entmakex (list '(0 . "LINE") (cons 10 ptw) (cons 11 (trans pt3 1 0))))
    Regards, M.R.
  1. Help with Trans function
    By LISP2LEARN in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Jul 2011, 07:00 pm
  2. separate commands for mirror (flip) and mirror (retain original)
    By designerstuart in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 28th Mar 2011, 04:18 pm
  3. entmake (trans pt 0 1)
    By Tharwat in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Jun 2010, 03:56 pm
  4. Lisp help (trans)
    By VisDak in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st May 2010, 10:06 am
  5. Invalid 2D point with mirror, WHY?
    By harrison-matt in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th May 2010, 05:18 am
