Results 1 to 10 of 10
    Forum Newbie
    AutoCAD 2011
    Nov 2011
    3
    Default Reconcile layers
    Every time some drawings are opened, they come up with a prompt to “Reconcile layers”, even though no new layers are being added to the drawings. Is there a way to fix this problem?
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,205
    The "problem" is that there are layers from an xref that have not been examined for their impact on the current drawing. To reconcile a layer (or layers), right-click on it (or them) in the Layer Manager and select "reconcile layer."
    breaking AutoCAD on a regular basis since 1991
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,104
    Or set LAYEREVAL to 0 to turn it off altogether.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Forum Newbie
    AutoCAD 2011
    Nov 2011
    3
    Default Reconcile layers permanently
    Quote Originally Posted by RaSha View Post
    That is what I am doing right now but my question was regarding a permanent fix to this problem, so one doesn’t have to repeat the same routine of reconciling layers every time the same drawings files are opened.
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,079
    _LAYERNOTIFY = 0 turns off alert notification.
    _LAYEREVAL = 0 turns off evaluation of new layers.
    _LAYEREVALCTL = 0 Disables the evaluation and notification of new layers and overrides the LAYEREVAL and LAYERNOTIFY setvars.
    Add the following bit of code to your ACADDOC.LSP file so it set the variable every time you open a drawing.
    Code:
    ;;; Turn off layer evaluation and notification
    (setvar "layerevalctl" 0)
  6. #6
    Forum Newbie
    AutoCAD 2011
    Nov 2011
    3
    All- Thanks a lot for your input.
    The solution works.
  7. #7
    Junior Member
    AutoCAD 2012
    Mar 2012
    14
    Quote Originally Posted by SLW210 View Post
    Code:
    Hi SLW210 - Sorry to open up an old thread but can I check a couple of things with you re. the bit of code?
    Is it "layerevalctrl" or layerevalctl (without the 2nd 'r')?
    Also, I don't have an ACADDOC.LSP file but I do have a ACA.LSP file with a bunch of different codes in (I'm using Acad 2012) Will it work if I drop it in there?
    Unreconciled layers are driving me nuts and as I'm the only one amending the xref'd file, I'm hoping I don't really need to know about them!
    Thanks, and sorry to open up the thread again
  8. #8
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    You only have to set that variable once and it should stay that way. No need to run the code everytime you open AutoCAD but it wouldn't hurt either.
    Drafting is a breeze.
  9. #9
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,079
    Correct, it is misspelled, I have corrected them.
    Open Notepad and add your code and save as acaddoc.lsp, acad.lsp only loads once (unless ACADLSPASDOC=1) and acaddoc.lsp loads with each drawing.
    RobDraw is correct, _LAYEREVALCTL is saved in the registry and "SHOULD" remain, these can get reset with third party add-ons and codes.
    _LAYERNOTIFY and _LAYEREVAL are saved in the drawing.
    P.S. Be sure to add acaddoc.lsp to a folder in the search path.
  10. #10
    Junior Member
    AutoCAD 2012
    Mar 2012
    14
    Thanks chaps, super helpful
  1. reconcile layers and plot
    By chelsea1307 in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jan 2009, 04:42 pm
  2. Auto Reconcile?
    By MarkytheSparky in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Sep 2008, 01:43 pm
  3. disable 'reconcile layers' dialogue based on autocad version
    By P Zero in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Jul 2008, 09:20 am
  4. Reconcile Layers
    By rookie37 in forum AutoCAD Drawing Management & Output
    Last Post: 24th Apr 2008, 04:48 am
  5. autocad reconcile layers
    By ANDY0871 in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Mar 2008, 11:26 pm
