CiCAD Posted November 29, 2011 Share Posted November 29, 2011 How do i add a description to a block that has already been created? Quote Link to comment Share on other sites More sharing options...
Grant Posted November 29, 2011 Share Posted November 29, 2011 If it is the block name you want to put a description into try 'Rename' command Quote Link to comment Share on other sites More sharing options...
CiCAD Posted November 29, 2011 Author Share Posted November 29, 2011 No. i do not want to rename it. i have blocks from other drawing i would like to copy into a dwg and then access them from the design center. i do not want to rename the block. i do not want to recreate the blocks as they have too many parasmeters and all work correctly. how ever i would like to add a description to the block so as when i am in the design center i can see the description. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 29, 2011 Share Posted November 29, 2011 Are the block names so cryptic that you can't tell from glancing at them what the block is? Isn't that what the Preview pane is for? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 29, 2011 Share Posted November 29, 2011 Issue the _BLOCK command, choose the block name and add the description, check the box for retain, hit OK and select Yes for redifine block. Dynamic blocks (also works on regular blocks), _BEDIT then Properties (once in Block Editor) expand the Block section and in Description fill it in as desired. Quote Link to comment Share on other sites More sharing options...
Grant Posted November 29, 2011 Share Posted November 29, 2011 Another way is to go into the file 'that you insert as a block into other drawings' and go into 'Drawing Properties' there. Under the 'Summary' tab there are a few fields. Quote Link to comment Share on other sites More sharing options...
