Did you try a different file? Maybe there's something hinkey with that one.
Strangely enough I find that I cannot upload a 128.8KB file something I'm sure I've done a few times or more in the past. Did I maybe reach some max limit of file uploads? If so, how do I delete previous files that I have uploaded to CT to make room for the new upload? Thanks.
Never try to teach a pig to sing. It wastes your time and annoys the pig. -Robert Heinlein
Had trouble as well trying to upload a JPG file to another thread. I can Select the file but cannot upload it. Weird.
I had a similar problem one day, but it went away. Never thought about it again till I saw your post.
Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
The first file was an AutoCAD DWG (saved in 2000 file format). Size: 128.8KB
I'll try again this morning. Maybe it had something to do with my Internet connection.
Thanks.
Satellite? Yes. Sunny, cold, dry morning.
I was just able to upload, by mistake, the same drawing saved in 2007 file format yet I cannot upload the drawing in 2000 file format. 2007 file size = 71KB. 2000 file size = 137KB (up 9KB since I first saved it). The damn thing just won't upload. I just checked some of the files I've uploaded in the past and found several that were larger in size so I have no idea why I can't get this one to load. Frustrating.
This is so weird.
I got it to work but I first had to insert another file before I could insert the one I really wanted then I had to delete the first one. Argh!!!!!!!!!!!!!!!!!!!!!!!
Well, I can't explain that. I don't *think* the problem is at this end - there's no obvious reason why you shouldn't be able to upload any DWG file under 1MB. I haven't tested every version but there's no record of a problem with any previous version. Sorry![]()
The problem resurfaced again today. Could not upload a simple PNG file via normal means. Had to resort to using the Basic Uploader.
