+ Reply to Thread
Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 39 of 39
  1. #31
    Senior Member
    Using
    AutoCAD 2009
    Join Date
    Jan 2008
    Location
    Dartmoor, Devon, UK
    Posts
    234
    Default
    Very gd advice so far - thanks - keep it coming
  2. #32
    Full Member
    Discipline
    Architectural
    Brands's Discipline Details
    Occupation
    Head of department, main drafter
    Discipline
    Architectural
    Using
    AutoCAD 2012
    Join Date
    Jul 2009
    Location
    IJmuiden, Netherlands
    Posts
    45
    Default
    Lee and Jack, thanks for the comments.
    Your advice really gives me a good view of your experience.
    Jack, you describe this process as being the change from the drawing board to CAD, a change that was in my eyes a great one, making production faster and easier to edit.
    ...So if this is the future of the drafting business it mean the change will come sooner or later, so there would be no point in pushing judgment day forward...Your company will either make it, or die in the process...
    (me thinking)
    Work is kind of slow now, so there would be time and room for learning something new. We don't have companies for clients, at least not in a way that they need to work in our drawings. So we're not bound by another companies' software.
    We are the first and last stage of the drawing process: we design, present, we get the building permits, we create the building drawings. (the package Autodesk is presenting as the circle to fit the Revit suite)
    My college did a Revit minor about a year ago, so he has an advantage when we would take training, thus making my transition easier.
    And if this is the future of the drafting business it mean the change will come sooner or later, so there would be no point in pushing judgment day forward...Your company will either make it, or die in the process...
    I'm going to moil this over and make a list of pro's vs con's for the companies switch.
    Thanks for the help!
  3. #33
    Senior Member
    Using
    AutoCAD 2009
    Join Date
    Jan 2008
    Location
    Dartmoor, Devon, UK
    Posts
    234
    Default
    Quote Originally Posted by Jack_O'neill View Post
    The intricate details of which you speak might best be done with Inventor
    That is interesting.
    I had a Mech Eng client who designed his hi-tech extension to Georgian terrace house, using Inventor (was instructive to see the lateral thinking and product sources he employed - he just called me in to solve Building Regulations issues etc). I saw the screen display, which seemed really hard to read, too much overlapping detail, and paper prints that somehow couldn't be made legible with lineweights etc.
    I wonder if a Mech Eng solid modeller really can handle buildings. I had a play with Alibre, which showed me that in Mech Eng you're assembling pre-formed components, whereas in building you're all the time installing cuboid objects and boolean trimming them against one another in situ. Alibre wasn't set up to do that at all. What's Inventor like then?
  4. #34
    Luminous Being Dadgad's Avatar
    Using
    AutoCAD 2013
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    6,042
    Default
    Here is a vertical building suite (premium) which can be downloaded for a free 30 day trial, including most of Autodesk's best stuff. It does not include Inventor, nor Navisworks, both of which are also available for 30 day free trials . While this would certainly give one a pretty good taste of a lot of different options, it would mean that you would have less time with each one, than if you took free trial versions of them individually in succession.
    Let's not forget that students can download free software too.
    Volume and repetition do not validate opinions forged in the absence of thought.
  5. #35
    Senior Member Lee Roy's Avatar
    Computer Details
    Lee Roy's Computer Details
    Operating System:
    Windows 8.1 Pro
    Computer:
    BOXX G2850-0-AX
    CPU:
    Intel Core i7-4790K @ 4Ghz
    RAM:
    32GB
    Graphics:
    nVidia Quadro K3100M
    Primary Storage:
    Samsung SM951 512GB - SSD
    Monitor:
    (2) Dell P2715Q & (1) Laptop screen
    Discipline
    Multi-disciplinary
    Lee Roy's Discipline Details
    Occupation
    CAD/BIM Manager @ AlfaTech (atce.com)
    Discipline
    Multi-disciplinary
    Details
    Architectural, Mechanical, Plumbing, Electrical...JOAT
    Using
    Revit 2016
    Join Date
    Apr 2011
    Location
    San Francisco, CA
    Posts
    433
    Default
    Have you tried AutoCAD's 3D capabilities? You're already proficient in AutoCAD, so try the 3D there in an environment you're already comfortable with.
    Revit is NOT like AutoCAD. If you got discouraged with SketchUp (easy peasy), you'll likely get the same from Revit. It's an entirely different piece of software and method of drawing. If you can understand that, then go for the 30-day trial and see what you think.
    "The thing about quotes on the internet is that you cannot confirm their validity." - Abraham Lincoln
    I -edit- a lot, sorry.
    The rotary engine is the most efficient way of converting fuel to noise ever invented.
    If my post sounds offensive, but can be meant in a non-offensive manner...I meant the latter.
  6. #36
    Senior Member
    Using
    AutoCAD 2009
    Join Date
    Jan 2008
    Location
    Dartmoor, Devon, UK
    Posts
    234
    Default
    Thanks Lee Roy. I will do that. Any idea which Acad version was it that got proper 3D incl boolean and I think I heard Sketchup-like push-pull facilities? Turbocad Pro has all that but is another learning curve.
  7. #37
    Forum Deity Jack_O'neill's Avatar
    Computer Details
    Jack_O'neill's Computer Details
    Operating System:
    xp
    Discipline
    Architectural
    Jack_O'neill's Discipline Details
    Discipline
    Architectural
    Details
    The bulk of my business is commercial curtainwall, site plans and floor plans. I do occasionally get a bit of tool and die, and the odd house now and again.
    Using
    AutoCAD 2010
    Join Date
    Sep 2008
    Location
    lost in the Arkansas wilderness
    Posts
    2,146
    Default
    Quote Originally Posted by Lee Roy View Post
    Absolutely...In fact, I've told others that the more experience you have in Autocad, , the harder it will be to learn Revit, or was for me. I kept expecting things to work a certain way, and they don't. Put everything you know about AutoCAD out of your head when you start on revit. It's a brave new world. In reality...I found Revit easier to get used to than Sketchup...thats one bit of software I don't think I will ever use. Nothing worked there like I thought it ought to!
    Never try to teach a pig to sing. It wastes your time and annoys the pig. -Robert Heinlein
  8. #38
    Using
    AutoCAD 2013
    Join Date
    Nov 2011
    Location
    Posts
    6,042
    Default
    Quote Originally Posted by fostertom View Post
    Autocad 2012 Vanilla has push-pull modeling.
  9. #39
    Luminous Being tzframpton's Avatar
    Computer Details
    tzframpton's Computer Details
    Computer:
    HP Zbook
    Discipline
    Multi-disciplinary
    tzframpton's Discipline Details
    Occupation
    BIM Specialist
    Discipline
    Multi-disciplinary
    Details
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Using
    Revit 2019
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    9,104
    Default
    Modeling in Revit is completely different too. In Revit you model things with a purpose. In AutoCAD you model things freely. With AutoCAD you don't have to plan much on most things. You just go with it and you can always do things in a random order. With Revit, since it is parametric you really have to understand where you need to end up before you ever start.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
Similar Threads
  1. Program to detect cheating in AutoCad
    By Mrdark in forum AutoCAD Drawing Management & Output
    Last Post: 31st Oct 2012, 07:47 pm
  2. Thinking of purchasing AutoCAD Electrical
    By jamesconti in forum Electrical
    Last Post: 29th Jan 2010, 03:40 am
  3. Replies: 0
    Last Post: 3rd Dec 2007, 05:51 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
