rock1 Posted December 7, 2011 Share Posted December 7, 2011 often i hatch two areas separately. is there any way to combine 2 adjacent hatches? for eg there are two adjacent rectangles which are hatched with same pattern hving the same scale. if i make the shape into a one single rectangle by trimming the middle line, i want to combine the two hatch into a one single hatch. how can i do this? Quote Link to comment Share on other sites More sharing options...
rock1 Posted December 7, 2011 Author Share Posted December 7, 2011 I'VE already seen fol. answers but it doesn't help. http://forums.autodesk.com/t5/AutoCAD-2010/Hatch-merge/td-p/2808162 http://www.cadtutor.net/forum/showthread.php?40379-Joining-Hatches Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 7, 2011 Share Posted December 7, 2011 (edited) Are the adjacent hatch patterns the same or different? If they are the same are the scale factors the same as well? Ask and ye shall receive. Don't ever say we don't go the extra mile for a forum member. http://autocadtips.wordpress.com/2011/11/23/autolisp-merge-hatches-join-hatches/ Edited December 7, 2011 by ReMark Quote Link to comment Share on other sites More sharing options...
rock1 Posted December 7, 2011 Author Share Posted December 7, 2011 yes they are exactly identical Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 7, 2011 Share Posted December 7, 2011 yes they are exactly identical What are you waiting for then? I provided you with the answer to all your prayers in my previous post. Get a move on dude! LOL Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 7, 2011 Share Posted December 7, 2011 rock1: Well? Did the lisp routine meet your requirements? Quote Link to comment Share on other sites More sharing options...
jvillarreal Posted December 9, 2011 Share Posted December 9, 2011 Originally posted at this site... http://www.cadtutor.net/forum/showthread.php?63600-Join-Hatches Quote Link to comment Share on other sites More sharing options...
Argentius Posted May 17, 2017 Share Posted May 17, 2017 rock1: Well? Did the lisp routine meet your requirements? I tried this routine, but it just made the entire Hatch disappear. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 17, 2017 Share Posted May 17, 2017 (edited) I tried this routine, but it just made the entire Hatch disappear. It worked for me the one and only time I tested it. I cannot say what caused it to fail in your case. Try this one by hmsilva. After loading it type the word "test" (without the quotes) to run the routine. In my test, this morning, it worked just fine. HatchMerge.lsp Out of curiosity I went back and tested the merge hatch routine I previously posted the link to (written by Jvillarreal). Once again it did work for me but the thing I don't like about it is that after the user has picked the first hatch pattern it has to be picked a second time along with the other hatch it will be merged with. So, in my test using two hatched squares I had to make a total of three picks. Using the routine by hmsilva in the same test I only had to make two picks. Both routines work; it's your choice as to which one you want to use. Edited May 17, 2017 by ReMark Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 17, 2017 Share Posted May 17, 2017 The results of testing both lisp routines. The example on the left used hmsilva's program. The example on the right used Jvillerreal's. Quote Link to comment Share on other sites More sharing options...
