Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    Senior Member Kemphas's Avatar
    Electrical
    Kemphas's Discipline Details
    Controls System
    Electrical
    Electrical 2015
    Mar 2010
    So~Cal
    106
    Default Locating and Deleting Layers
    So i run into the problem where I copy from one project to the next to save time, also from templates and what not. Well there isn't really a uniform nature to my drawings as i started doing them under necessity rather design...
    So, i try to delete duplicate layers.. or Layer's and it continues to give me errors... stating every time:
    The following layers cannot be deleted:
    Layers 0 and Defpoints
    The current layer
    Layers containing objects
    Xref-dependent layers
    Well, its not Layer 0 or Def Points, Its not the current layer and i even deleted all pages except the one mandatory and CTRL+A - DEL... Zoom extents on model and do the same thing, and i cannot get rid of the layer....
    So yeah? how do i get rid of the pesky layers? Can i type a command that changes all XXXX layer to XXX layer and can dump the ones into such as "0" layer and be unconcerned about it freeing it up to delete the unwanted un used layer?
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    I'd suggest you use the PURGE command instead of manual deletion through the Layer Properties Manager. Some layers (i.e., 0, Defpoints) are there for a reason.
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,954
    Try using -PURGE and purge Empty text objects and Zero length lines, THEN PURGE your Layers.
    AutoCAD 2013
    Nov 2011
    5,994
    You can use LAYMRG and select the layers by name, and merge the "phantom layer" into Layer 0, or any other layer of your choosing, and after you have selected your target layer it will ask for confirmation of your layer merge intention. After it is done merging the selected layer into the target layer it will delete the offending layer.
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    You can use brute force on the pesky ones. The Layer Delete command. But be forewarned...it will delete the layers even if they have objects on them. Be careful what you wish for.
  6. #6
    AutoCAD 2013
    Nov 2011
    5,994
    I have had on a number of occasions layers which I could not delete any other way than with the LAYMRG command, not by purging nor by the layer delete function. Perhaps if i had tried the -PURGE option at the command line I might have been able to. I thought that you couldn't delete layers which were in use? I usually just use the right click shortcut command for delete in the layer properties manager though. As a last resort? All else has failed? LAYMRG.
  7. #7
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Using the layer merge command does not get rid of the object(s) that are preventing you from deleting the layer. It's just a work around in this situation. Not a solution.
    Drafting is a breeze.
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    From Lynn Allen's blog of August, 2005.
    "The awesome Express Tool LAYDEL will come to your rescue. Of course you've installed the Express Tools - you'll find Delete Layer under the Layer sub-menu of the Express Tools. This command does not care what is on the layer - it is happy to vanish it into oblivion. Even if that layer is referenced in a block definition, LAYDEL is smart enough to open that block definition, remove the layer from the block, and then delete the layer - now that is power! But remember...where there is power - there is Danger! So be careful what you ask for...Since the layer doesn't have to be empty to be removed with LAYDEL - your drawing could definitely incur some damage if you aren't paying attention."
  9. #9
    AutoCAD 2013
    Nov 2011
    5,994
    thanks, I missed that. I always install the express tools and give them a good look over, but 2005 was long before my journey began.
  10. #10
    Electrical
    Controls System
    Electrical
    Electrical 2015
    Mar 2010
    So~Cal
    106
    Quote Originally Posted by remark View Post
    you can use brute force on the pesky ones. The layer delete command. But be forewarned...it will delete the layers even if they have objects on them. Be careful what you wish for.
    ctrl+z = friend
  1. Deleting layers
    By reyems in forum AutoCAD Beginners' Area
    Last Post: 12th Mar 2009, 01:29 pm
  2. Deleting Layers
    By Aubrey86 in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Sep 2008, 12:54 am
  3. deleting layers
    By Figment in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Jan 2008, 05:49 pm
  4. deleting layers
    By drahcir in forum AutoCAD Drawing Management & Output
    Last Post: 1st Mar 2007, 02:10 pm
  5. Deleting Layers
    By MIKEB19 in forum AutoCAD General
    Last Post: 27th Jul 2006, 02:41 pm
