Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 21
  1. #11
    Senior Member Kemphas's Avatar
    Electrical
    Kemphas's Discipline Details
    Controls System
    Electrical
    Electrical 2015
    Mar 2010
    So~Cal
    106
    Purge worked for the majority of my layers..
    Nother questions related to layers. i have 2010LT, how do i print to PDF without printing the layers with it and colors? I have used CutePDF (freeware pdf printing software for anything you can print)
  2. #12
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    You want to print in monochrome right?
  3. #13
    Electrical
    Controls System
    Electrical
    Electrical 2015
    Mar 2010
    So~Cal
    106
    I also want to get rid of the pdf's side bar that allows you to see what the layers are and turn them on / off.
    If i print simply monochrome it will shade the colors into grey's so i dont think thats what i want.. i want 1 color for the program and i want it to simply print BLACK... without having to go in and change all the colors to the layers every time.
  4. #14
    Junior Member
    AutoCAD 2008
    Sep 2011
    23
    Quote Originally Posted by Dadgad View Post
    You can use LAYMRG and select the layers by name, and merge the "phantom layer" into Layer 0, or any other layer of your choosing, and after you have selected your target layer it will ask for confirmation of your layer merge intention. After it is done merging the selected layer into the target layer it will delete the offending layer.
    Aweosome!!it works....thank you so much!!
  5. #15
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Quote Originally Posted by srichang View Post
    Yeah the layer is gone but do you know what was on that layer? If not, then you are just covering up what was keeping you from deleting/purging that layer.
    Drafting is a breeze.
  6. #16
    Forum Newbie
    AutoCAD 2011
    Dec 2011
    1
    The best way is to use "Layer Translator".
    Import the same drawing in the "Translate Box". Then you translate the layer "to delete" with de layer "you want to save". It always works even with Xref-dependent layers.
  7. #17
    Senior Member AlinOz's Avatar
    AlinOz's Computer Details
    Windows 7 64 bit
    HP xw4600
    6GB
    AutoCAD 2011
    Feb 2009
    Brisbane, Australia
    151
    Quote Originally Posted by Kemphas View Post
    Kemphas,
    This is a full AutoCAD, but I'm pretty sure the same will aplly in LT. Open your plot dialogue, select the DWG to PDF plotter. Next to it, you will find a 'Configure' Button. That will take you to the "plotter configuration editor" dialogue. Select Custom Properties in the top area and the Custom Proerties Button will appear at the bottom. Selecting this will open the DWG to PDF Properties Dialogue wherein you will find the "Include Layer Information" checkbox - uncheck it and Bob's yer Uncle...
    If you think there must be a better way, There probably is!!! AlinOz's overview of AutoCAD http://www.idraftdesign.com.au
  8. #18
    Electrical
    Controls System
    Electrical
    Electrical 2015
    Mar 2010
    So~Cal
    106
    Thank's alinoz
  9. #19
    Junior Member
    AutoCAD 2008
    Sep 2011
    23
    Quote Originally Posted by RobDraw View Post
    Yup...i did try to find them out...but failed ....there was nothing in the layer when i isolated it and ctrl+a....the file doesn have any xrefs either...any suggestions on where they could be hiding....??
  10. #20
    AutoCAD 2013
    Nov 2011
    6,056
    Possibly empty text objects, or zero length lines. if so, then the -PURGE entered at the commandline might be useful, or using the AUDIT > (Y) command, followed by a purge, sometimes new stuff turns up.
  1. Deleting layers
    By reyems in forum AutoCAD Beginners' Area
    Last Post: 12th Mar 2009, 01:29 pm
  2. Deleting Layers
    By Aubrey86 in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Sep 2008, 12:54 am
  3. deleting layers
    By Figment in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Jan 2008, 05:49 pm
  4. deleting layers
    By drahcir in forum AutoCAD Drawing Management & Output
    Last Post: 1st Mar 2007, 02:10 pm
  5. Deleting Layers
    By MIKEB19 in forum AutoCAD General
    Last Post: 27th Jul 2006, 02:41 pm
