Results 1 to 2 of 2
    Super Member JPlanera's Avatar
    JPlanera's Computer Details
    Win7 x64
    Dell T7400
    (4) Intel Xeon CPU X5272 @ 3.4GHz
    8G
    NVIDIA Quadro FX 570 & RADEON X6000
    80G main
    1TB ext
    (3) DELL 21" wide
    Mechanical 2012
    Sep 2010
    Chicago
    526
    Default Archive xrefed drawing while saving layer info...
    I am trying to develope a routine that will allow me to send an assembly drawing to an archived location. This drawing contains multiple xrefs with various layer controls (some on some off). My current routine copies the entire drawing to the clip board, opens a new drawing, pastes from the clip board and explodes and binds the xrefs. THe problem is, the layer controls are all turned on now. Is there a way to accomlish this while "saving" all of the layer information so that when this routine is complete, the layers that were "OFF" in the source drawing remain "OFF" in the archive drawing???
    You might be an engineer, if you tell people that time travel does not exist..... and then 5 minutes later explain how you would build a time machine
    Engineers aren't boring people, we just get excited over boring things.
    Senior Member
    Architecture 2011
    Dec 2010
    172
    Have you tried doing an etransmit?
    dJE
  1. copying parts of xrefed drawing
    By Urte in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Oct 2010, 01:19 pm
  2. XRef Layer Info
    By scottkelley80 in forum AutoCAD Drawing Management & Output
    Last Post: 30th Nov 2009, 06:09 pm
  3. one layer info to many layers?
    By arkmonica in forum Map 3D
    Last Post: 12th May 2009, 11:15 am
  4. Need info about Drawing standards
    By vinod in forum AutoCAD Drawing Management & Output
    Last Post: 19th Nov 2007, 05:12 pm
  5. Command Macro Gets Layer/Linetype Info
    By Dan in forum AutoCAD Drawing Management & Output
    Last Post: 21st Aug 2006, 07:54 pm
