Results 1 to 6 of 6
    Junior Member
    AutoCAD 2000
    Dec 2011
    10
    Default Need help making a routine to insert a certain set of blocks all at once at 0,0?
    I use autocad 2000 at my job to create drawings for CAM. The machining paths are numbered between 521-850 (this is the block name) each time with numbers being used throughout this range, not nessecarily in order. What I want to do is get only these numbered blocks to insert all at once with one command at 0,0. Question one: Can I get a list of just the block names with autolisp? Question 2: Can I filter the block names with some sort of < > cond? or will I have to go about that another way?
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,249
    Check this out ... Would insert all your block at the coordinates 0,0,0 and would print the name of your inserted blocks to the command line ..
    Code:
    (defun c:TesT (/ Block Blockname lst)
      (while
        (setq Block (tblnext "BLOCK" (null Block)))
         (entmake
           (list '(0 . "INSERT")
                 (cons 10 '(0. 0. 0.))
                 (cons 2 (setq Blockname (cdr (assoc 2 Block))))
                 '(41 . 1.)
                 '(42 . 1.)
                 '(43 . 1.)
                 '(50 . 0.)
         (setq lst (cons Blockname lst))
      (print lst)
    Junior Member
    AutoCAD 2000
    Dec 2011
    10
    Default I will try it out.
    Thanks Man! Too bad I have to wait until I get to work tonight to try it out.
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,249
    Quote Originally Posted by jeremyearle5 View Post
    No problem ,
    And forgot to say , welcome to the forum .
    Tharwat
  5. #5
    Super Member marko_ribar's Avatar
    marko_ribar's Computer Details
    Windows 7 Ultimate X64
    Intel quad core CPU 4x2.66GHz, 8GB RAM
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    NVIDIA GeForce 6600 GT
    250 GB
    500 GB
    Samsung 17''
    Architectural
    marko_ribar's Discipline Details
    Architecture, project designer, project visualisation
    Architectural
    space design - modeling and animations
    AutoCAD 2014
    Feb 2010
    Belgrade, Serbia, Europe
    1,297
    Maybe this :
    Code:
    (defun BlocksFound ( / a b )
        (while (setq a (tblnext "BLOCK" (null a)))
            (if
                (and
                    (/= 4 (logand 4 (cdr (assoc 70 a))))
                    (if (assoc 1 a) (not (findfile (cdr (assoc 1 a)))) T)
                (setq b (cons (cdr (assoc 2 a)) b))
        b
    (defun sortblocklist ()
      (vl-sort (blocksfound) '(lambda ( a b ) (< a b)))
    (defun filterblocklist ( / pref stno enno no blname filtbllst )
      (setq pref (getstring T "\nInput prefix for blocks : "))
      (setq stno (getint "\nInput start number for filtering block list : "))
      (setq enno (getint "\nInput end number for filtering block list : "))
      (setq no (- stno 1))
      (while (<= no enno)
        (setq no (1+ no))
        (setq blname (strcat pref (itoa no)))
        (if (member blname (sortblocklist)) (setq filtbllst (cons blname filtbllst)))
      (setq filtbllst (reverse filtbllst))
    (defun c:insfilblcks nil
      (foreach bl (filterblocklist)
        (command "_.-insert" bl "0,0,0")
        (while (eq 1 (logand 1 (getvar 'cmdactive))) (command ""))
    M.R.
  6. #6
    Junior Member
    AutoCAD 2000
    Dec 2011
    10
    It worked great Marko! I just switched out the user input with the starting and ending numbers I needed. I appreciate it.
  1. autolisp routine to read coordinates and insert entities points
    By teknomatika in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Sep 2010, 06:51 pm
  2. Routine to insert Xref's
    By rami_9630 in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Mar 2010, 02:48 pm
  3. Making a toolbar icon for a lisp routine
    By Organic in forum AutoCAD General
    Last Post: 16th Apr 2009, 09:37 pm
  4. Replies: 2
    Last Post: 12th May 2008, 03:22 pm
  5. Making a sub routine public
    By muck in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Mar 2007, 12:47 pm
Tags for this Thread
