Need help making a routine to insert a certain set of blocks all at once at 0,0?
jeremyearle5
I use autocad 2000 at my job to create drawings for CAM. The machining paths are numbered between 521-850 (this is the block name) each time with numbers being used throughout this range, not nessecarily in order. What I want to do is get only these numbered blocks to insert all at once with one command at 0,0. Question one: Can I get a list of just the block names with autolisp? Question 2: Can I filter the block names with some sort of cond? or will I have to go about that another way?
Check this out ... Would insert all your block at the coordinates 0,0,0 and would print the name of your inserted blocks to the command line ..
(defun c:TesT (/ Block Blockname lst)
 (while
   (setq Block (tblnext "BLOCK" (null Block)))
    (entmake
      (list '(0 . "INSERT")
            (cons 10 '(0. 0. 0.))
            (cons 2 (setq Blockname (cdr (assoc 2 Block))))
            '(41 . 1.)
            '(42 . 1.)
            '(43 . 1.)
            '(50 . 0.)
    (setq lst (cons Blockname lst))
 (print lst)
Maybe this :
(defun BlocksFound ( / a b )
   (while (setq a (tblnext "BLOCK" (null a)))
       (if
           (and
               (/= 4 (logand 4 (cdr (assoc 70 a))))
               (if (assoc 1 a) (not (findfile (cdr (assoc 1 a)))) T)
           (setq b (cons (cdr (assoc 2 a)) b))
   b
(defun sortblocklist ()
 (vl-sort (blocksfound) '(lambda ( a b ) (< a b)))
(defun filterblocklist ( / pref stno enno no blname filtbllst )
 (setq pref (getstring T "\nInput prefix for blocks : "))
 (setq stno (getint "\nInput start number for filtering block list : "))
 (setq enno (getint "\nInput end number for filtering block list : "))
 (setq no (- stno 1))
 (while (<= no enno)
   (setq no (1+ no))
   (setq blname (strcat pref (itoa no)))
   (if (member blname (sortblocklist)) (setq filtbllst (cons blname filtbllst)))
 (setq filtbllst (reverse filtbllst))
(defun c:insfilblcks nil
 (foreach bl (filterblocklist)
   (command "_.-insert" bl "0,0,0")
   (while (eq 1 (logand 1 (getvar 'cmdactive))) (command ""))
M.R.
