Results 1 to 6 of 6
    Forum Newbie
    AutoCAD 2012
    Dec 2011
    9
    Default Some simple questions
    1. How does the stretch command work? I'm trying to scale an object solely in the Y-direction. Is making a block out of all the objects I want to scale the only way to do this?
    2. I have a few blocks that I want to make icons for so that I can just click them from the ribbon. Is this possible?
    3. How can I set text defaults? i.e. I'm inserting a lot of multi-line text and I always want to justify it MC (middle center) but the default is TL I believe, is there anyway to change this?
    Thanks
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,074
    Quote Originally Posted by ssartor View Post
    It depends on the object. A rectangle for instance can be stretched in the Y direction very easily, whereas a polygon will not stretch accordingly. Making a block is definitely one of the easiest ways to stretch/scale something in a single axis. I know there are LISP routines that are floating around that expedite this function very effectively.
    Look into using Tool Palettes instead. This will do everything you are asking in this particular request. They are a vital part of any designer's needs for block repository and customization needs.
    Sure. First you'll want to get familiar with the Tool Palettes like I noted above. This way you can create a Block from a MTEXT object, which basically saves the settings. Using Tool Palettes you can access this MTEXT object to quickly insert it into your drawing, without any need for adjustments.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Forum Newbie
    AutoCAD 2012
    Dec 2011
    9
    Thanks, for the answers. Where is a good place to learn more about tool palettes?
    Super Member resullins's Avatar
    resullins's Computer Details
    Windows 10
    Dell Precision T5500
    Intel Xeon E5405
    12.00 GB
    NVidia Quadro FX 4500
    Dual Dell 20" 16x9 running DVI-D
    AutoCAD 2017
    Feb 2011
    Nashville, TN
    675
    If you can register with Autodesk University, do that. Look up the Archived lessons, and search for Tool Palettes. I learned from the one by Mike Murphy, he's pretty good!
  5. #5
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,728
    Quote Originally Posted by resullins View Post
    ... Mike Murphy, he's pretty good!
    Is it Mike or Matt?
  6. #6
    Windows 10
    Intel Xeon E5405
    12.00 GB
    AutoCAD 2017
    Feb 2011
    Nashville, TN
    675
    You're right... it's Matt. I do know a Mike Murphy though. Whoops.
  1. A few simple questions!
    By djp6 in forum AutoCAD Beginners' Area
    Last Post: 20th Sep 2010, 03:07 pm
  2. Simple Dynamic Block creation questions...
    By MrButtonmush in forum AutoCAD Beginners' Area
    Last Post: 8th Sep 2010, 04:28 pm
  3. Some Simple Autolisp Questions.
    By SteveK in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Aug 2009, 04:29 pm
  4. 2 simple questions
    By alijahed in forum AutoCAD General
    Last Post: 1st Oct 2007, 10:37 am
  5. Simple simple, huh? rectangles how are they built?
    By Anna_here in forum AutoCAD Beginners' Area
    Last Post: 2nd Aug 2006, 09:18 pm
Tags for this Thread
