Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
    Forum Newbie
    AutoCAD 2012
    Dec 2011
    9
    Default Linetype scale in paper vs. model space
    Ok, so I have this drawing that I just finished. There were a few dotted lines that were showing up correctly in model space. Then, when I switched over to paper space all of those lines were solid. I messed around with the option LTSCALE and set it to 0.01. This made the lines show up correctly in paper space, but now they are all messed up in model space. Is there an option to make it so they show up exactly the same in both model and paper space?
    Thanks
    Super Member resullins's Avatar
    resullins's Computer Details
    Windows 10
    Dell Precision T5500
    Intel Xeon E5405
    12.00 GB
    NVidia Quadro FX 4500
    Dual Dell 20" 16x9 running DVI-D
    AutoCAD 2017
    Feb 2011
    Nashville, TN
    675
    Attach the file please... I'll take a look.
    Forum Newbie
    AutoCAD 2012
    Dec 2011
    9
    MOTOR_CIRCUIT_AND_DB_SUPPLY.dwg
    Here is the file. Thanks for the help.
    Windows 10
    Intel Xeon E5405
    12.00 GB
    AutoCAD 2017
    Feb 2011
    Nashville, TN
    675
    When you're in your linetypes dialogue box, check your GLOBAL SCALE box... they should be set to 1. Then go back to your drawing and set all your individual lines to linetype scale 1. You've messed up your global settings somehow.
  5. #5
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,147
    Also when in Linetype Manager, uncheck the box for "Use paper space units for scaling"
  6. #6
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,216
    Try setting MSLTSCALE and PSLTSCALE to 1.
    breaking AutoCAD on a regular basis since 1991
  7. #7
    Forum Newbie
    AutoCAD 2012
    Dec 2011
    9
    Both are set to 1.
    How do I get to the linetypes dialogue box?
  8. #8
    Super Member ScribbleJ's Avatar
    ScribbleJ's Computer Details
    Windows 7
    Dell Precision T3500
    Intel(R) Xeon(R) CPU W3530 @ 2.8GHz 2800 Mhz
    12 gig
    Nvidia Quadro 600
    237 GB
    Main: Dell 2408 Aux: Dell 1703FP
    Civil
    ScribbleJ's Discipline Details
    Civil Design Tech for Water / Waste Water Industry.
    Civil
    Roadway designs, water and waste-water treatment systems and water distribution systems.
    Civil 3D 2014
    Dec 2008
    Rancho Cordova, CA
    541
    Quote Originally Posted by ssartor View Post
    Command: LINETYPE [or LT]
    Then click the button Show Details (If 'Details' are already being displayed the Hide Details will be displayed).
    Also:
    Command: LTSCALE
    Calvin
    Soli Deo Gloria
  9. #9
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    You set the phantom line to an object linetype scale of 14, change that to 1. Now the width of your diagram is in the 25' range so your cannoscale needs to be set to 3/8"=1' or something close to that if working in metric.
    Set ltscale between .5 to 1, psltscale to 1.
    In Paperspace, make the layout active and set the cannoscale to 3/8" or a close metric equivalent if working in metric.
    Consider adding layers for things like the phantom line rather than setting it per object.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  10. #10
    Forum Newbie
    AutoCAD 2012
    Dec 2011
    9
    What exactly would I type in to make that change? It keeps saying input invalid whenever I try to change it to 3/8.
  1. Help getting the right scale from Model Space to Paper Space
    By Susan-Skye in forum AutoCAD Drawing Management & Output
    Last Post: 28th Oct 2010, 01:51 pm
  2. Annotative scale for model & paper space
    By CivilPrice in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 27th Aug 2010, 07:06 pm
  3. One more with model space / paper space linetype confusion
    By the-trooper in forum AutoCAD Drawing Management & Output
    Last Post: 11th Mar 2010, 02:37 pm
  4. Scale the lintype in model space & paper space.
    By yadavdinesh2008 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 27th May 2009, 06:14 pm
  5. linetype scale in Model Space/Paper Space
    By delangorgon in forum AutoCAD General
    Last Post: 2nd Oct 2007, 04:55 pm
Tags for this Thread
