Results 1 to 7 of 7
Thread: Ellipse size
    Forum Newbie
    AutoCAD 2008
    Dec 2011
    3
    Default Ellipse size
    Hello,
    I have more of a geometry question, rather than CAD question. I need to determine the size of a spar hole for an airplane wing. The wing will be cut out of foam with a hot wire. There is a round spar hole in the wing that runs from the root to the tip on each wing half. A carbon fiber rod goes through it. Seems easy, but the wing is swept back 35 degrees, so round hole will actually be an ellipse is when it exits the root and tip. The hole needs to be 5mm. The ellipse will be 5mm tall, but how do I figure out how wide?
    Thanks!
    Brian
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,103
    I would draw it out. Basically, it appears that you have two 5mm wide objects crossing at 35 degrees. So draw them. The ellipse will be 5mm high but will be as wide as the intersection of the two.
    I drew the ellipse by clicking on the two intersections for the major axis, and then inputting on the keyboard 2.5mm as the minor axis.
    Super Member
    not specified
    Dec 2004
    YUL
    587
    or simply calculate major axis =>> 5/cos35
    Forum Newbie
    AutoCAD 2008
    Dec 2011
    3
    Thanks Eldon. You're exactly right. The width has been right in front of me the whole time.
  5. #5
    Forum Newbie
    AutoCAD 2008
    Dec 2011
    3
    Thanks Paul. Can you please explain how to use cos?
    Thanks!
    Brian
  6. #6
    Super Member
    not specified
    Dec 2004
    YUL
    587
    0123456789
  7. #7
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    If you are doing this in 3D then I would simply place a rectangle at the desire angle.
    The width of the rectangle should be 1/2 the drill size.
    Then revolve the "drill" and subtract.
    No calculations required.
  1. How to distinguish between Ellipse and Ellipse Arc?
    By Ahankhah in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Sep 2011, 01:25 pm
  2. Ellipse Not Right
    By gsksun4 in forum AutoCAD Beginners' Area
    Last Post: 25th Mar 2010, 04:34 pm
  3. plotting d size e size paper
    By Elvis in forum AutoCAD Beginners' Area
    Last Post: 30th May 2009, 06:29 pm
  4. Ellipse
    By johnengineer in forum AutoCAD Drawing Management & Output
    Last Post: 30th Mar 2007, 12:55 am
  5. Plot size on server is much larger than drawing size
    By chewy-d in forum AutoCAD Drawing Management & Output
    Last Post: 1st Nov 2003, 03:25 pm
