Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    Senior Member
    rickh's Computer Details
    W7 x64
    8G
    1G
    Structural
    rickh's Discipline Details
    Designer
    Structural
    Civil 3D 2011
    Feb 2011
    Houston
    156
    Sometimes, depending on how you started the drawing, or modified units, you will need to Reset the scalelist (and note that a scale currently in use will not get reset to anything).
    If you type SCALELISTEDIT, you should get a dialog box showing the ratio of modelspace units to paperspace units (press F1 also to find detailed information).
    Your modelspace units are Meters, and Paperspace units are MM, so the 1:100 scale should read as '1 paper unit = 0.1 drawing units". Check my math here, but this is (1M/1000MM)*100. Note also that the ratio is all that matters, so it could also be "10 paper units = 1 drawing units" (same ratio). I would Reset the scales first, and then just scroll through them to check that they are all correct.
  2. #12
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Post your drawing so we can take a look at it.
    Save it in AutoCAD 2000 or 2004 file format so people who have an older release of AutoCAD can have an opportunity to open the drawing. Not everyone is using the latest edition of AutoCAD like you and I are. BTW...AutoCAD 2012 saves to the 2010 file format.
  3. #13
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    I tried to duplicate what you did and my results are similar. At 1:50 a 16x14 meter box looks too small. If I bump this up to 1:2 however it fits nicely on my A3 (420x297) sheet.
  4. #14
    Forum Newbie
    Shane Cawthorn's Computer Details
    DELL INSPIRON 5030
    AutoCAD 2012
    Dec 2011
    ALIWAL NORTH, EASTEN CAPE, SOUTH AFRICA
    8
    Hi rickh
    thanks, your advise does seem to work. I think now my biggest problem is solved.
    You are great.
    Once again thanks
  1. Linetype scale in paper vs. model space
    By ssartor in forum AutoCAD Beginners' Area
    Last Post: 16th Dec 2011, 09:14 pm
  2. Help getting the right scale from Model Space to Paper Space
    By Susan-Skye in forum AutoCAD Drawing Management & Output
    Last Post: 28th Oct 2010, 01:51 pm
  3. Annotative scale for model & paper space
    By CivilPrice in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 27th Aug 2010, 07:06 pm
  4. Scale the lintype in model space & paper space.
    By yadavdinesh2008 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 27th May 2009, 06:14 pm
  5. linetype scale in Model Space/Paper Space
    By delangorgon in forum AutoCAD General
    Last Post: 2nd Oct 2007, 04:55 pm
