Results 1 to 7 of 7
    Forum Newbie
    not specified
    Apr 2006
    5
    Default Another viewport question
    When i am in the paper space I adjust the scale to what I want, but then when i click on the model tab, my drawing shrinks drastically. Now, this does not happen on all drawing that i do. Most of the time i can go between the model and paper space without distorting the drawing!
    Please help!
    -Ken
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,068
    are you putting your viewports to scale, or just resizing the drawing inside the viewport?? once you set a viewport to the desired scale, it won't effect your model space, and doesn't have any reference other than changes made in model space.
    i guess im confused, be more specific.
    Forum Newbie
    not specified
    Apr 2006
    5
    I am trying to put the drawing to scale. In the model space, I find what I want in the viewport. Then I go to the paper space and make the scale what I want it. but when I increase or decrease the scale, it moves the drawing. So when i click the model space again just to move the drawing were i want it, the drawing shrinks and i have to find what i want all over again. it is becoming very fustrating!!
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    Change the setting of UCSFOLLOW. Set it while in viewport as it's viewport specific. If set to "1" it should no longer "zoom extents".
  5. #5
    Senior Member
    not specified
    Feb 2006
    Guelph, Ontario
    436
    sounds like your zooming out when you're in model space. best thing to do it once you have what you want in your viewpoort in paperspace in the right scale lock your viewport. If you go back to model space the model should be just as you left it unless you do a zoom operation. If you zoom extents and the model goes out so far that you can't see it anymore then chances are that you have an entity sitting somewhere in model space far away from your model. find that entity and erase it and do another zoom extents and you should zoom right into your model.
    Hope that doesn't sound too confusing.
    Mike
  6. #6
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,068
    Quote Originally Posted by lockettk
    go to paperspace, right-click the viewport edge, go to Properties. Scroll down the Properties window until you get to Misc. Under the "Standard Scale" pull-down menu, click which scale you want. you might have to try a few. start out with something small, like 1/8"=1' and work your way up until you have the desired size. once you're done, Esc out of the Properties window, go back to model space and keep continuing what you were drawing.... when you go back to Paperspace it'll still be there, as long as you dont MOVE anything that was in the viewport. is this what you're looking for??? lol
  7. #7
    Forum Newbie
    not specified
    Apr 2006
    5
    Thank you so much!! You saved my computer from getting thrown out the window!
