Results 1 to 5 of 5
    Forum Newbie
    AutoCAD 2012
    Sep 2011
    3
    Default Autocad 2012 student question
    I need to find the center of a circle that is tangent to another circle and a point on a line. I cannot use tangent tangent radius, Any suggestions.
    Full Member dirkvandonkelaar's Avatar
    dirkvandonkelaar's Computer Details
    Windows 10 x64
    ATEC Performance One P180 Mini - Black
    Asus M4A78-EM
    AMD Phenom II X4 945, 3,0GHz
    2x Kingston ValueRAM KVR800D2N5K2, 2GB
    ASUS Radeon HD 5700, 512 MB
    Samsung Spinpoint F3 HD103SJ, 1TB, RAID1
    Synology DS415+, 4x3TB RAID 5
    Samsung SyncMaster 2232BW
    Multi-disciplinary
    dirkvandonkelaar's Discipline Details
    Construction
    Multi-disciplinary
    Architectural, Engineering
    AutoCAD 2017
    Apr 2011
    Overberg, The Netherlands
    71
    can you post the file, so i can take a look at it?
    "The only job where you start at the top, is digging a hole."
    Forum Newbie
    AutoCAD 2012
    Sep 2011
    3
    The circle that is complete has a radious of 108. I need a circle with a radious of 102 that is tangent to that circle and tangent to a point 54 mm to the right of the start of the rectangle.
    Windows 10 x64
    Asus M4A78-EM
    Multi-disciplinary
    Construction
    Multi-disciplinary
    AutoCAD 2017
    Apr 2011
    71
    does the circle with the radius of 102mm need to be 54mm tot he right of this point of the rectangle?
  5. #5
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,040
    Quote Originally Posted by metsj373 View Post
    Usually you need to do a bit of temporary construction to find the centre.
    Offset the circle by the new radius, so that you know that the centre of the new circle will lie somewhere on this offset line. Then draw a circle, centred on the line point, with a radius of your new circle, and where the two intersect is the proper centre of the new circle.
  1. autocad 2012 student version
    By thereclinerman5 in forum AutoCAD Beginners' Area
    Last Post: 18th Dec 2011, 06:34 pm
  2. Auto Desk Inventor 2012 (Student) Install help!?!
    By United Pumpkins in forum Hardware & Operating Systems
    Last Post: 31st Oct 2011, 08:17 pm
  3. AutoCAD 2012 and AutoCAD LT 2012 Service Pack 1 Released
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 7th Sep 2011, 01:34 am
  4. Replies: 0
    Last Post: 1st Sep 2011, 04:20 am
  5. Replies: 0
    Last Post: 13th Aug 2011, 01:30 am
