Results 1 to 5 of 5
Thread: Plotting
    Forum Newbie
    AutoCAD 2007
    Dec 2011
    2
    Default Plotting
    How do I set my paper space to print A3 am using autocad 2007 and have spend days trying to figure it out. How to I get a title block/template to fit A3. Please help is Urgent
    Full Member dirkvandonkelaar's Avatar
    dirkvandonkelaar's Computer Details
    Windows 10 x64
    ATEC Performance One P180 Mini - Black
    Asus M4A78-EM
    AMD Phenom II X4 945, 3,0GHz
    2x Kingston ValueRAM KVR800D2N5K2, 2GB
    ASUS Radeon HD 5700, 512 MB
    Samsung Spinpoint F3 HD103SJ, 1TB, RAID1
    Synology DS415+, 4x3TB RAID 5
    Samsung SyncMaster 2232BW
    Multi-disciplinary
    dirkvandonkelaar's Discipline Details
    Construction
    Multi-disciplinary
    Architectural, Engineering
    AutoCAD 2017
    Apr 2011
    Overberg, The Netherlands
    71
    You can change the default plotting manager (the window you see when you press CTRL+P), by typing "pagesetup" end edit the default.
    in this window, you can select A3 as the paper size as shown in the picture below.
    if you want to print an A3 layout, you can select under "what to plot", the window tab and you will be prompt for an window. In the scale tab you can set the scaling.
    I reccomend selecting the "Center the plot", because this will center the selected window to the paper.
    Then set the drawing orientation to the needed orientation.
    I hope i helped you with your problem
    "The only job where you start at the top, is digging a hole."
    Forum Newbie
    AutoCAD 2007
    Dec 2011
    2
    I did but my title block with the drawing doesnt fit the paper space what could be the problem?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,736
    It may not fit because you forgot to take into account those dashed lines one sees in a layout that represent the limits to which AutoCAD will plot. I vaguely recall there is a way around this but I can't tell you what it is. This came up in discussion recently (within the last month I believe).
  5. #5
    Windows 10 x64
    Asus M4A78-EM
    Multi-disciplinary
    Construction
    Multi-disciplinary
    AutoCAD 2017
    Apr 2011
    71
    for this issue, I always draw an inner rectangle, offsetted 10mm from the outer line, which is the paper size.
    This way, the title block is visible and, for me, the drawing looks nicer than without border.
  1. CAD 2010 plotting on HPdesignjet 500: DWG's not plotting, but no error?
    By Mauser in forum AutoCAD Drawing Management & Output
    Last Post: 31st May 2010, 06:43 pm
  2. Plotting to a PDF in 09
    By gamerfreak in forum AutoCAD General
    Last Post: 16th Sep 2008, 11:33 am
  3. Plotting
    By happyunited in forum AutoCAD Drawing Management & Output
    Last Post: 12th Feb 2008, 04:03 pm
  4. Plotting Help
    By Marcus in forum AutoCAD Beginners' Area
    Last Post: 15th Sep 2006, 10:27 pm
  5. CAD Plotting, A0 A1 A2
    By digiscans in forum Useful Links
    Last Post: 31st May 2005, 01:21 pm
