Results 1 to 7 of 7
    Forum Newbie
    AutoCAD 2000
    Dec 2011
    3
    Smile How did they do it? A Mysterious Block Locked for Editing
    I was very intrigued by a customer/clients DWG. It had all these, 'equipment envelopes'. They were blocks that were locked from editing/exploding. There were many of them. I could REFEDIT and save/discard changes, but that changed all the blocks. I noticed that the block had two 'parts', in the REFEDIT it appeard to have two files, a block within a block. I finally realized wblock (save block as) would allow me to actually 'get into' the block. So, that problem is solved (thanks in part to this website and its tutorials/forums).
    I'm still very curious, however.
    How did they do that?
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,128
    Does the block have a name?
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows XP Pro
    Dell Optiplex 330
    Civil
    CyberAngel's Discipline Details
    Civil Drafter
    Civil
    Civil 3D 2013
    Jul 2006
    Anywhere Else
    977
    As SLW implies, they may be anonymous blocks. You can also define a block so that it can't be exploded, which apparently makes it read-only too.
    breaking AutoCAD on a regular basis since 1991
    Forum Newbie
    AutoCAD 2000
    Dec 2011
    3
    Smile The blocks had names.
    Yes, the block (and all the others in the DWG alike and not) had a name. When I selected the containing layer... the 'main' blocks could be hidden (light bulb icon). What remained was a 'circumscribed' pinkish square or rectangle. A 'pink' block. All the main blocks had their own pink blocks. The pink blocks reminded me of viewports... for its respective main block. If only visually, and not functionally. In REFEDIT, I could move the 'main' block separate from the 'pink' block. When I saved the change, the 'pink' block didn't cut parts off of the 'main' block. So, they didn't act much like viewports except that they were all originally drawn as a sort of border. Very strange. The blocks might very well have been just a visual grouping. Again, in the REFEDIT dialog box, there was a sort of file tree and it showed a 'main' block and 'sub-block'. A sort of 'sublayer' block for the main block. Many of these 'pink-sub-layer-blocks' were called out as "Equipment Envelopes". I had to select them all manually and delete them to remove them from view in the model space.
    How do you you make those sub-layered blocks? What is the benefit? I've never come across them before.
    (The dwg was converted from an incompatible version to 2000 compatible, my version is ACAD2k) Could it be something to do with the conversion?
  5. #5
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    4 GB RAM
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,128
    Sounds like they are nested blocks.
  6. #6
    Forum Newbie
    AutoCAD 2000
    Dec 2011
    3
    Smile
    Any suggestion for a good nested block tutorial?
    Bonus question: Any suggestion for a good LISP tutorial?
    Thank you for quenching my curiosity
  7. #7
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    4 GB RAM
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,128
  1. Dont snap to Locked Stuff! / Lock a block or Object!
    By TimZilla in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Jan 2011, 07:37 pm
  2. Locked block
    By bobsy852 in forum AutoCAD Beginners' Area
    Last Post: 4th Aug 2010, 05:11 pm
  3. Mysterious Circles Out of Nowhere
    By BIGMIKE09281946 in forum AutoCAD Beginners' Area
    Last Post: 13th Jan 2010, 05:48 am
  4. Mysterious red circle...
    By jnywu in forum AutoCAD General
    Last Post: 25th Oct 2009, 04:09 am
  5. Can't Move Locked Attributes In A Block
    By thegodplato in forum AutoCAD Drawing Management & Output
    Last Post: 25th Sep 2009, 01:38 pm
Tags for this Thread
