Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Super Member Bill Tillman's Avatar
    AutoCAD 2013
    Oct 2008
    Miami, FL
    874
    Default Excel File Troubles
    I am trying to become an expert on interfacing between Excel and AutoCAD in a relatively short period of time. So for now I am stumbling through many of these issues. This morning I found what seems to be a nice collection of LISP code which can work with Excel files, it's called GetExcel.lsp. I've learned a lot by studying the code so far but there are some problems I can't seem to figure. First off, the dreaded (vl-load-com) issue. It was puzzling to me why developers leave this out of the code until I read Lee Macs insightful posting about ACADDOC.lsp.
    I have a very simple spreadsheet with values in only 3 cells. When I call the GetExcel part of the code I keep getting this message:
    ; error: Automation Error. Excel cannot access 'Template'. The document may be
    read-only or encrypted.
    The file in question is neither open by anyone else, nor is it set to R/O. I can post the code I'm using but it's rather lengthy and is available at this URL:
    http://web2.iadfw.net/terrycad/LISP/GetExcel.lsp
    My goal is to learn how to open any Excel file, read in the required data, and then be able to create a quick drawing based on the values being dimensions. I think I can handle that part if I can just find a way to get the data from Excel into my AutoCAD file.
    Thanks again and I appreciate everyone's patience. I realize this is brutal explaining to a novice from experienced programmers here at this forum.
    It's deja vu, all over again.
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,744
    Hi Bill,
    You've set yourself quite a challenge! In the past I've written quite a few applications which interface with Excel, some freeware, some not, but in my opinion, one of the most difficult parts about working with Excel is the size of the Excel API coupled with the layout of the MSDN documentation which can be like navigating through a maze at times.
    Here are some examples from theSwamp which may help you towards your goal:
    http://www.theswamp.org/index.php?topic=31441.0
    http://www.theswamp.org/index.php?topic=10101.0
    http://www.theswamp.org/index.php?topic=35157.0
    Lee Mac Programming
    Just another Swamper
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,744
    Here is the MSDN Documentation:
    Excel Object Model Reference
    Excel Object Model Map
    Lee Mac Programming
    AutoCAD 2013
    Oct 2008
    Miami, FL
    874
    Thanks alot. I'm in a real pickle in that I've been out of work for the last few months and need a job badly. A local firm has asked me to assist and if I can prove that at least I can get the basics done, I might land a long term project with them. They want to interface between Exel and AutoCAD. My programming skills aren't the best but their improving everyday so here's to catching this train.
  5. #5
    Forum Deity BlackBox's Avatar
    Civil 3D 2011
    Nov 2009
    3,952
    Good luck, Bill!
    "Potential has a shelf life." - Margaret Atwood
  6. #6
    AutoCAD 2013
    Oct 2008
    Miami, FL
    874
    It's starting to gel for me. I have gotten the GetExcel code to return the list *ExcelData@ and it contains this:
    (("1" "2" "3")) which is something like what I expected because cells A1, B1 and C1 contain the values 1,2 and 3 respectively. I was having a brain fart earlier and got that part wrong.
    So I want to parse this now and isolate the three items in this list so I can assign them to variables. In my haste I tried:
    (setq pt1 (car *ExcelData@))
    which I am assuming will return "1" or just 1 as its the first item in the list. But instead pt1 ends up being ("1" "2" "3") with only one set of the paranthesis being removed.
    Okay I'm seeing the light now. If I ask for (car *ExcelData@) I will get the list with the outside parens removed because that's actually the first item in the list. Then I ask for (car pt1) and I get "1"....hooray, but how can I get rid of the quotes? Or is it necessary to convert this to a number as I plan on using these values as dimensons eventually to draw some simple shapes like rectangles and lines, etc..
  7. #7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,744
    Code:
    (mapcar 'atof (car *ExcelData@))
    Lee Mac Programming
  8. #8
    AutoCAD 2013
    Oct 2008
    Miami, FL
    874
    Code:
    (setq pt1 (mapcar 'atof (car *ExcelData@)))
      (setq pt2 (car pt1))
      (setq pt3 (cadr pt1))
      (setq pt4 (caddr pt1))
    This gets me where I wanted to be today. The three values now assigned to something I can work with in AutoCAD and do some drawings. Now I'm dangerous. As they say, I now know enough to really screw things up....!
    Today, a simple spreadsheet....Tomorrow, the World!
  9. #9
    Super Member ScribbleJ's Avatar
    ScribbleJ's Computer Details
    Windows 7
    Dell Precision T3500
    Intel(R) Xeon(R) CPU W3530 @ 2.8GHz 2800 Mhz
    12 gig
    Nvidia Quadro 600
    237 GB
    Main: Dell 2408 Aux: Dell 1703FP
    Civil
    ScribbleJ's Discipline Details
    Civil Design Tech for Water / Waste Water Industry.
    Civil
    Roadway designs, water and waste-water treatment systems and water distribution systems.
    Civil 3D 2011
    Dec 2008
    Rancho Cordova, CA
    539
    Bill do you happen to have AutoCad Map 3D? If so the task at hand can be much easier. I will leave it at that until you reply other than Map 3D has the same functionality as ArcGIS software does in respect to database files (i.e. converted Excel files). Once you get your data into Map 3D you can make thematic maps with it.
    Calvin
    Soli Deo Gloria
  10. #10
    AutoCAD 2013
    Oct 2008
    Miami, FL
    874
    No, I'm not using 3D Civil, I more of an architectural/structural user. So plain vanilla AutoCAD is what I have to work with.
    I had so many distractions today but was able to get back and play around some more with the GetExcel.lsp program. Turns out there is another module in it called GetCell which does the parsing of the data as well and you can simply ask for it to:
    Code:
    (setq pt6 (GetCell "C1"))
    and it will give you the value in cell "C1". Still, I'm learning alot more about how to interface between Excel and AutoCAD. Each day I know 100% more than I did yesterday.
  1. import excel file
    By silviu30 in forum AutoCAD General
    Last Post: 8th Aug 2010, 12:35 pm
  2. Excel File In R14
    By gsksun4 in forum AutoCAD Beginners' Area
    Last Post: 27th Jan 2010, 03:15 pm
  3. Insert Excel file to Cad
    By BEKA in forum AutoCAD Drawing Management & Output
    Last Post: 9th Jan 2010, 05:37 pm
  4. EMAILING DWG FILE AND LOSEING EXCEL FILE
    By J-LYLE in forum AutoCAD Drawing Management & Output
    Last Post: 6th Jun 2006, 10:09 pm
  5. Referencing an Excel File
    By WwhawkwW in forum AutoCAD General
    Last Post: 2nd Nov 2005, 09:50 am
