jhm Posted December 29, 2011 Share Posted December 29, 2011 Hello, Maybe someone can help me with this, i can't find the solution? For example I've a few points with some attributes (select point,properties and you see the different attributes of this point), one of those attributes is a textstring. It has a value (Dreumel). This textstring (value) is what i want to see and put in to the drawing. I want to display this value See the attachment please. And how to this with many more points? Thanks and a happy newyear, jhm Quote Link to comment Share on other sites More sharing options...
Murph_map Posted December 29, 2011 Share Posted December 29, 2011 That property is an AutoCAD MAP3D object (object data table vaule). You can use the map3d anno blocks to label those points, or do a alter-property query and add text, or convert the points to SDF and data connect then label or.......... See there's a number of ways of doing it. The quickest for me would be the annon blocks. PS: Why are you using MY intials as your name. Quote Link to comment Share on other sites More sharing options...
