dnyandevp Posted January 3, 2012 Share Posted January 3, 2012 In my code there is previous condition to draw polyline Arc. Which are handled as shown bellow, 1 . Getting three points eg. Pt1, pt2, pt3 (which are 2d points). 2 . creating object of AcGeCircArc2d. Eg. AcGeCircArc2d* arc2D = new AcGeCircArc2d(); 3 . set three points to AcgeCircArc2d. Eg. arc2D>set(Pt1, pt2, pt3 , error); 4. Angles of arc , direction and bulge is calculated shown bellow double fStartAngle = arc2D->startAng(); double fEndAngle = arc2D->endAng(); int nClockWise = arc2D->isClockWise(); // fBulge = tan((fEndAngle - fStartAngle ) / 4); 5 . At last bulge and vertex is added to acDbPolyline AcDbPolyline *pPolyLine pPolyLine->addVertexAt(pPolyLine->numVerts(),Pt1 ,(nClockWise ? -fBulge : fBulge); pPolyLine->addVertexAt(pPolyLine->numVerts(),pt3); By using abouve code Arc is drawn using acdbPolyline (2D Vertex). But I want to draw same arc by using acDb3dPolyline. I found that there method is not available to set bulge to acdb3dpolylineVertex . Is there any way to draw arc by using acbd3dPolyline. Please help... Quote Link to comment Share on other sites More sharing options...
SEANT Posted January 3, 2012 Share Posted January 3, 2012 The AcDb3dPolyline entity does not support Bulge/Arcs. One workaround would be to segment an arc with some quantity of line segments. Another option – given that you are using unmanaged code – would be to create your own custom entity that supports 3d segments and arcs. The docs warn against deriving from AcDb3DPolyline, but you may be able to simulate the proper graphics from the spline entity. Quote Link to comment Share on other sites More sharing options...
