Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 52
    Junior Member
    AutoCAD 2011
    Jan 2012
    19
    Default How to draw a 2D Spring ?
    Hi guys, firstly my apologies if i posted in the wrong section of the forum.
    Can i ask how to draw a spring that is wound from 8mm diameter wire with an inside diameter of 22mm, the standard for a spring consist of one and a half turns at each end and the center lines throught each side. Springs are normally wound and then ground at each end to give a flat surface for accurate seating. (this is taken from part of a question)
    It will be great if there are step by step guidelines for me to follow as i am still quite a newbie to autocad.
    I am currently using autocad 2011.
    Thanks alot
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    You will want to learn the line and trim commands along with offset and array commands. Tangent osnap will also be needed.
    Any technical drafting textbook I have seen has a bit on springs (check the Fasteners chapter).
    Go ahead and do what you are able to get done (even if not correct) and attach your dwg file here.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Draw the spring in 3D using the HELIX command then use the FLATSHOT command to generate a top and front view.
    Super Member DANIEL's Avatar
    Mechanical
    DANIEL's Discipline Details
    Industrial
    Mechanical
    AutoCAD 2013
    May 2005
    Arlington Texas
    1,005
    Could you not just use the HELIX command to create the spring in 3D then use the FLATTEN command to obtain the 2D view?
    would seem easiest to do it as a solid and then do a solview and a soldraw.
    If you would like to help my 2 year old niece Alaina in her battle against Leukemia you can donate blood at any Carter Blood Care and put SPON050875 on the donor form. Thank you so much for any contributions in this matter that you can make.
    Luminous beings are we, not this crude matter.
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Ah....Daniel....I changed my approach. See my previous post.
    Or there is this....
    http://www.xaraxone.com/webxealot/workbook19/page_6.htm
  6. #6
    Mechanical
    Industrial
    Mechanical
    AutoCAD 2013
    May 2005
    Arlington Texas
    1,005
    even easier
  7. #7
    Junior Member
    AutoCAD 2011
    Jan 2012
    19
    Quote Originally Posted by JD Mather View Post
    Hi Sir, thanks for the quick reply. Unfortunately my autocad textbook doesn't have the chapter on springs
    May i know inside diameter of 22mm is from which point to which?
    Thanks
  8. #8
    Junior Member
    AutoCAD 2011
    Jan 2012
    19
    HI Daniel & ReMark thank you for the quick reply.. Although i have attended 6 lessons of autocad, i am still not that good : if you don't mind can you teach me how you guys do it in a simpler way? I am eager to learn all kinds of method to further improve my skills and knowledge in autocad.
    Thanks.
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Do you know how to change your workspace?
  10. #10
    Junior Member
    AutoCAD 2011
    Jan 2012
    19
    do you mean the top left corner button 2D/Annotation, 3D Basics, 3D Modelling, etc...?
  1. How do I draw a spring in autoCAD?
    By cyter in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Apr 2011, 08:57 pm
  2. How Do You Draw A Spring????
    By sceejays in forum AutoCAD General
    Last Post: 12th Nov 2007, 08:46 pm
  3. How do I draw a spring in 3D?
    By paulstall70 in forum AutoCAD General
    Last Post: 14th Jun 2007, 05:56 am
  4. How to draw a spring in 3D...?
    By usm in forum AutoCAD General
    Last Post: 29th May 2006, 06:55 am
  5. How do I draw a spring in 3D?
    By visith in forum AutoCAD General
    Last Post: 8th Apr 2005, 09:17 am
