Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 52
  1. #11
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    An example of a 3D coil created using the HELIX command.
  2. #12
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Yes, you want to change to the 3D Modeling workspace.
    On the Home tab > Draw panel click on the black arrow to the right of the word Draw. In the drop-down section you'll see an icon that looks like a spring/coil. Click on that to start the Helix command. Use the following (bold text) as your inputs....
    Command: _Helix
    Number of turns = 3.0000 Twist=CCW
    Specify center point of base:
    Specify base radius or [Diameter] <3.0000>: 3
    Specify top radius or [Diameter] <3.0000>: 3
    Specify helix height or [Axis endpoint/Turns/turn Height/tWist] <1.0000>: 12
    When you're done come back here, tell us what you see, then we'll give you further instructions.
  3. #13
    Junior Member
    AutoCAD 2011
    Jan 2012
    19
    ok Remark thank you for all your replies, i need to hit sack as it is getting late. i will try to google myself on how to use the helix command and get back to you tomorrow if i encounter any problems. thanks.
  4. #14
    Junior Member
    AutoCAD 2011
    Jan 2012
    19
    ok sure, thanks alot for the step by step guidelines. i will catch you guys tomorrow hopefully hahaha.. till then take care..
  5. #15
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Just when it was going to get interesting. Oh well....good night.
  6. #16
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    Quote Originally Posted by autocat View Post
    Hi Sir, thanks for the quick reply. Unfortunately my autocad textbook doesn't have the chapter on springs
    May i know inside diameter of 22mm is from which point to which?
    You might check your library for a book like Gieseck, et al Technical Drafting.
    The inside diameter (ID) is the largest cylinder that would fit through the center of the spring.
  7. #17
    Forum Newbie
    kotheinzaw's Computer Details
    Windows Seven Starter
    Acer
    AutoCAD 2007
    Jan 2012
    Germany
    1
    Thank you so much sir. I was download all of your files.
    Zaw
  8. #18
    Junior Member
    AutoCAD 2011
    Jan 2012
    19
    I'm sorry for the late reply. I have followed your steps and i think i only see a circle
  9. #19
    AutoCAD 2013
    Nov 2011
    5,992
    Attachment 32118
    You should go into a different perspective view, say isometric, as what you see is not always what you get. You may have gotten it right, just hard to tell from top view. Or you can use the ORBIT command to go into your 3D modelspace and take a little look around.
    I just noticed you've got the viewcube displaying up in the right hand corner, go ahead and click on one of the corners and take a look.
  10. #20
    Junior Member
    AutoCAD 2011
    Jan 2012
    19
    yea i see a spring now.. Thanks Dadgad for the tip..
  1. How do I draw a spring in autoCAD?
    By cyter in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Apr 2011, 08:57 pm
  2. How Do You Draw A Spring????
    By sceejays in forum AutoCAD General
    Last Post: 12th Nov 2007, 08:46 pm
  3. How do I draw a spring in 3D?
    By paulstall70 in forum AutoCAD General
    Last Post: 14th Jun 2007, 05:56 am
  4. How to draw a spring in 3D...?
    By usm in forum AutoCAD General
    Last Post: 29th May 2006, 06:55 am
  5. How do I draw a spring in 3D?
    By visith in forum AutoCAD General
    Last Post: 8th Apr 2005, 09:17 am
