Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Forum Newbie
    awolcott's Computer Details
    Win7 Ultimate
    AutoCAD 2012
    Jan 2012
    8
    Default Break line into equal distanced segments
    I have searched throughout the forums, both Microstation and AutoCAD and can't find anything of this manner.
    I have a line. I must break this line into segments of equal distance, say 10 nautical miles, which at my location is .3177. My X,Y is in lat/long. So basically X=.3177 and/or Y=.3177 is also equal to 10NMs.
    Is it possible to break my single continuous line into separate elements which are equidistant in length, and then delete every other line, so as to emulate a dashed line?
    I would use line types, however I must export the data to a program which will display individual, solid lines, but does not support line types. I have to show these lines as "dashed", with the dashes 10NMs in length with 10NMs between each one.
    Thanks.
    Andrew
    Forum Deity BlackBox's Avatar
    Civil 3D 2011
    Nov 2009
    3,951
    If using AutoCAD, consider the MEASURE and DIVIDE commands.
    "Potential has a shelf life." - Margaret Atwood
    Senior Member the ber's Avatar
    AutoCAD LT 2013
    Nov 2006
    Germany
    187
    You can use MEASURE to divide your line into specified lengths, but it will still be a line, and you might not see the division points. I think it would be easier to use ARRAY: draw one line at the correct length, and then select ARRAY. You then specify how many "rows" or "columns" you want, depending upon which axis your line is on. The spacing should be double your line length, or .6354. You can prevue your lines before you accept them.
    Sooner or later, you'll own Generals.
    Civil 3D 2011
    Nov 2009
    3,951
    I do not know many projects where there is a 10NM 'straight line'.
    Instead, the two commands mentioned can place points, or blocks at the specified intervals, and then the line may be manually 'broken' at each accordingly.
  5. #5
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,134
    Is this a Microstation or AutoCAD question?
    I think I once ran across a LISP or a request for a LISP to change a dashed linetype to individual lines.
  6. #6
    Forum Newbie
    Win7 Ultimate
    AutoCAD 2012
    Jan 2012
    8
    Quote Originally Posted by the ber View Post
    I'll give this a shot. I know there is a way, but as with all things that are worth doing, they are worth doing well. Doing them well however takes a bit of time! LOL. Thanks!
    Quote Originally Posted by RenderMan View Post
    You are right taking into consideration the curvature of the earth. However, the data I am working from has been converted to DXF directly from a lat/long text file source. So, when converted back the lines do place correctly, since the program uses a simple projection system; 60NMs per degree of Latitude, and 42.66 NMs per degree of longitude.
    Of course this had to be taken from the point of tangency of a 386,319 sq. mile area
    Anyhow I've played around with the above commands, but as I have nearly 100 lines to do this with, this may become a time consuming adventure LOL.
    Thanks for the replies!
    Andrew
  7. #7
    Forum Newbie
    Win7 Ultimate
    AutoCAD 2012
    Jan 2012
    8
    Quote Originally Posted by SLW210 View Post
    Microstation specifically, as I prefer to work in Microstation, V8i. However, AutoCAD pointers are an option as well. I would prefer those to be PM'ed, or otherwise split from this thread and placed in the appropriate AutoCAD forum.
  8. #8
    Civil 3D 2011
    Nov 2009
    3,951
    Quote Originally Posted by awolcott View Post
    ... I just threw up in my mouth a little.
  9. #9
    Forum Newbie
    Win7 Ultimate
    AutoCAD 2012
    Jan 2012
    8
    Okay I tried the path array method in AutoCad. It works, but only if I draw the line to be arrayed in the same orientation as the original line(path) to be followed.
    Next up is to try the measure function in Autocad.
  10. #10
    Forum Newbie
    Win7 Ultimate
    AutoCAD 2012
    Jan 2012
    8
    LOL. Don't get me wrong, as I am new to both. But for my purposes I find Microstation to be somewhat more user friendly. However, I find that to accomplish my goals I generally bounce back and forth between Microstation and AutoCAD.
  1. how to divide an ellipse in equal segments?
    By pvd in forum Autodesk Inventor
    Last Post: 10th Apr 2010, 07:51 am
  2. Convert Any Length Arc into Equal Segments
    By EricDevault in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Mar 2010, 12:20 pm
  3. Possible LISP request - Break up a circle into equal parts
    By CADMASTER1128 in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Oct 2009, 06:10 pm
  4. coplanar line segments over line segments
    By MattHamby in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th Feb 2009, 07:48 pm
  5. Break lines into individual segments?
    By nscherneck in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Oct 2006, 11:29 pm
