Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
  1. #11
    Senior Member the ber's Avatar
    AutoCAD LT 2013
    Nov 2006
    Germany
    187
    Before you try the MEASURE command, you should use DDPTYPE to set the appearance of the points. Use a cross or circle or something; if you use the default AutoCAD setting, then you won't see the points. If your line is just a straight line, then you should be alright. If your line is a polyline, then I think your specified distance of 10 NM will be shortened at each corner.
    Sooner or later, you'll own Generals.
  2. #12
    Full Member caddcop's Avatar
    caddcop's Computer Details
    WinXP
    Lenovo ThinkPad Laptop - Dual Screens on Docking Station
    Dell and Viewsonic 22' Widescreens
    Civil
    caddcop's Discipline Details
    CADD Manager - Civil/Survey
    Civil
    Working with Land Desktop 2008 and 2009, Civil 3D 2009, 2010, 2011, 2012 & 2013
    Land Desktop 2009
    Sep 2009
    Maryland (DC Suburbs)
    94
    The construct points tools could help you place points where you need to partial delete element segments. You may also be able to use the snap divisor setting (KY=) to create snap points. Also, you might be able to use a macro.
    A custom line style is not an out of the question possibility since there is a drop linestyle command which would leave lines and gaps. you could use a unit base linestyle that would be used with the global linestyle scale factor equal to the gap required.
  3. #13
    Forum Newbie
    awolcott's Computer Details
    Win7 Ultimate
    AutoCAD 2012
    Jan 2012
    8
    Quote Originally Posted by caddcop View Post
    Just want to clarify for others, and myself, that you are speaking about Microstation, correct?
    If so, does anyone know if there an equivalent command for Autocad?
    Edit:
    BTW, thank you for the input. I am now exploring this option and so far I like what I see.
  4. #14
    WinXP
    Civil
    Civil
    Land Desktop 2009
    Sep 2009
    94
    That is correct. There is a family of construct points tools that is similar to measure/divide. And the snap divisor lets you set "midpoint" snaps, except that you can specify, thirds, quarters, fifths, etc. The shortcut key-in is KY=X where X is an integer number representing the number of segments to subdivide something into. Lets say you want to divide something into equal length segments and delete every other segment, leaving dashes and gaps, but want a dash at each end. Set a divisor that is an odd integer, like 7. With the partial delete command, you can delete the segment between the sixth and fifth segment. After you have completed that step, you would need to decrease the divisor by 2, since what is left is now 5 segments long. After deleting the fourth segment, reduce it to 3 and delete the middle third.
    It might be possible to make a macro that combines all of these steps based upon the length of the element, its end points and the number of segments desired.
    As this was the MicroStation forum, I answered with MicroStation work flows. I'm pretty sure that some of the lisp gurus could offer some thoughts.
  5. #15
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,199
    In AutoCAD you can WMFOUT then WMFIN, though the lines will need to be scaled once reinserted.
    I found a LISP HERE, did not check to see if it worked.
  6. #16
    Senior Member
    rickh's Computer Details
    W7 x64
    8G
    1G
    Structural
    rickh's Discipline Details
    Designer
    Structural
    Civil 3D 2011
    Feb 2011
    Houston
    152
    Quote Originally Posted by awolcott View Post
    looks like some lisp routines to do just what you want in Autocad:
    http://www.cadtutor.net/forum/showth...Splitting-Line
  1. how to divide an ellipse in equal segments?
    By pvd in forum Autodesk Inventor
    Last Post: 10th Apr 2010, 07:51 am
  2. Convert Any Length Arc into Equal Segments
    By EricDevault in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Mar 2010, 12:20 pm
  3. Possible LISP request - Break up a circle into equal parts
    By CADMASTER1128 in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Oct 2009, 06:10 pm
  4. coplanar line segments over line segments
    By MattHamby in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th Feb 2009, 07:48 pm
  5. Break lines into individual segments?
    By nscherneck in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Oct 2006, 11:29 pm
