Mr Latic Posted January 6, 2012 Share Posted January 6, 2012 Hi. Baffled by this one! I have a title block that when inserted in the drawing 1st time all is well, colours are correct, close the drawing down & re-open & all the colours are redefined to the layer it's inserted on.! Now, if i press U (undo) 3 times it reverts back to it's orginal state, colours etc. find attached F2 info: Redefining colors for block: _a0_J .undo Current settings: Auto = On, Control = All, Combine = Yes, Layer = Yes Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] : end .regen Regenerating layout. Command: Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk application or Autodesk licensed application. Now if I do the same thing in MEP2012 all is well! !! Any ideas, SETVAR perhaps???? Thanks. Quote Link to comment Share on other sites More sharing options...
Organic Posted January 6, 2012 Share Posted January 6, 2012 That is the same problem as http://www.cadtutor.net/forum/showthread.php?12558-Redefining-color-for-block which doesn't have a solution listed in that thread What file format are you saving it as (AutoCad 2010 or AutoCad2000 etc) from AutoCad 2012? Quote Link to comment Share on other sites More sharing options...
Mr Latic Posted January 9, 2012 Author Share Posted January 9, 2012 Thanks for the reply. Yip, same problem. Tried Saving in different formats but same thing. Only way I can see is putting the objects on seperate layers. Now the same thing does not happen if I open the drawing in AutoCAD MEP2012! ! ! ! The "Redefining colors for block:" does not come up! Quote Link to comment Share on other sites More sharing options...
