Results 1 to 6 of 6
    Full Member
    AutoCAD 2012
    Nov 2011
    71
    Question Moving a layout to another file
    I have two files. I messed one up I was using the solview method (I hear that method is outdated...) Anyway, I digress... and I rotated the model in the model tab creating quite a mess.
    Unfortunately, the layout associated with that file, is gorgeous. (ok, I'm biased.)
    I went looking around my flash drive, through the good graces of win explorer, and I found a file another file of the same project that was in better condition, because, the position of the model hadn't been moved. There is no layout associated with this file.
    However, I need to get the first layout over to this file. I thought of using the Autodesk Design Center (ADC) <---keyboard alias --- So, I did, but it wouldn't import the layout. It imported layout #2 which is just a copy of the model; which I don't need.
    It did say that it wouldn't import the titleblock, which is a block which was ignored. But everything I've drawn is *not* a block.
    So, how do I get that layout over to the other file, that has the good model?
    Thanks in advance.
    (Sorry for the long-ish post.)
    TMC
    Cadding like mad and getting nowhere fast
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    To put it simply, you want to copy a layout from one drawing to another, right?
    I can't wait for a reply. Here you go. Lynn Allen explains it so well even a CADman can do it.
    http://lynn.blogs.com/lynn_allens_bl...o-another.html
    Full Member
    AutoCAD 2012
    Nov 2011
    71
    Thanks it worked like a charm.
    TMC
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    You're entirely welcomed.
    SolView/SolDraw have their place in the bag of tricks available for extracting 2D views from 3D objects. Each user must decide for themselves what works best in any given situation.
  5. #5
    Senior Member daft vader's Avatar
    MEP 2008
    Jul 2006
    uk
    171
    Silly question but couldnt you just undo any changes you made to correct it ?
  6. #6
    Full Member
    AutoCAD 2012
    Nov 2011
    71
    As they say in the other forum, of which I'm a member, (I'll paraphrase; using your word instead).
    There are no silly questions; only silly answers.
    daft vader: Great U/N by the way...I think I saved the changes to the file. So I was stuck. (I rotated the solview model; and it became out of place.)
    So, in my case, having a backup model, (thankfully) I found it easier just to move layouts from the model I rotated, to the one that was still in position.
    ReMark: I'm going to look into Flatshot, after my class is over. I've read somewhere that Solview/Soldraw is not the preferred method for data extraction.
  1. Moving Layout Tabs
    By Simple153 in forum AutoCAD Drawing Management & Output
    Last Post: 8th Sep 2009, 11:25 pm
  2. moving mouse quickly causes cad file an error.
    By edwin in forum AutoCAD General
    Last Post: 19th Aug 2009, 09:05 am
  3. Moving from Model to Layout view
    By AlexB in forum AutoCAD Beginners' Area
    Last Post: 8th May 2009, 09:49 pm
  4. Moving image to layout template
    By JamFam in forum AutoCAD Beginners' Area
    Last Post: 14th Feb 2009, 12:52 pm
  5. Moving Customization file from 2004 to 2008?
    By Dana in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Sep 2007, 11:17 am
