Results 1 to 5 of 5
    Full Member
    AutoCAD 2012
    Dec 2011
    Prague, Czech republic
    64
    Default polygonal viewport
    hi,
    in layout i used polygonal viewport. when i want to convert to file.pdf the border line was still ok, althought i put it in the layer off.
    thanks
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,058
    Try putting the viewport on its own layer then freezing the layer before plotting to PDF format.
    Super Member Organic's Avatar
    Civil
    Civil 3D 2013
    Feb 2009
    1,641
    You have to drag a selection window over the viewport, then if you click in the properties pane and look at the objects selected, it is not one viewport, it is a viewport AND a polyline. Place BOTH on the layer that is off or set to not print etc.
    Full Member
    AutoCAD 2012
    Dec 2011
    64
    ok, i will try it
  5. #5
    Super Member ScribbleJ's Avatar
    ScribbleJ's Computer Details
    Windows 7
    Dell Precision T3500
    Intel(R) Xeon(R) CPU W3530 @ 2.8GHz 2800 Mhz
    12 gig
    Nvidia Quadro 600
    237 GB
    Main: Dell 2408 Aux: Dell 1703FP
    Civil
    ScribbleJ's Discipline Details
    Civil Design Tech for Water / Waste Water Industry.
    Civil
    Roadway designs, water and waste-water treatment systems and water distribution systems.
    Civil 3D 2011
    Dec 2008
    Rancho Cordova, CA
    539
    Another way to do this without having to freeze the layer your viewport is on is to set the viewport layer to no plot. That way you don't have to thaw the layer if you want to change it again.
    Calvin
    Soli Deo Gloria
  1. Polygonal Viewport synced with View in SSM?
    By StykFacE in forum AutoCAD Drawing Management & Output
    Last Post: 7th Sep 2011, 01:18 pm
  2. Text in Polygonal viewport
    By jowie in forum AutoCAD Drawing Management & Output
    Last Post: 24th Sep 2008, 07:03 am
  3. creating a polygonal viewport from a standard
    By nicnicman in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 16th Sep 2008, 01:02 am
  4. Polygonal Viewport
    By jowie in forum AutoCAD Beginners' Area
    Last Post: 7th Sep 2008, 07:58 am
  5. Polygonal Viewport -pdf
    By Voogd in forum AutoCAD Drawing Management & Output
    Last Post: 12th Apr 2006, 07:15 pm
