bartymic Posted January 9, 2012 Share Posted January 9, 2012 hi, in layout i used polygonal viewport. when i want to convert to file.pdf the border line was still ok, althought i put it in the layer off. thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 9, 2012 Share Posted January 9, 2012 Try putting the viewport on its own layer then freezing the layer before plotting to PDF format. Quote Link to comment Share on other sites More sharing options...
Organic Posted January 9, 2012 Share Posted January 9, 2012 You have to drag a selection window over the viewport, then if you click in the properties pane and look at the objects selected, it is not one viewport, it is a viewport AND a polyline. Place BOTH on the layer that is off or set to not print etc. Quote Link to comment Share on other sites More sharing options...
bartymic Posted January 9, 2012 Author Share Posted January 9, 2012 ok, i will try it Quote Link to comment Share on other sites More sharing options...
ScribbleJ Posted January 9, 2012 Share Posted January 9, 2012 Another way to do this without having to freeze the layer your viewport is on is to set the viewport layer to no plot. That way you don't have to thaw the layer if you want to change it again. Quote Link to comment Share on other sites More sharing options...
