Results 1 to 9 of 9
    Full Member wings's Avatar
    Architectural
    wings's Discipline Details
    Project Manager
    Architectural
    AutoCAD 2009
    Sep 2011
    Northeast U.S.A.
    55
    Question Xref Does Not Show Up
    I've inserted an external reference (as an attachment), but it does not show up in my drawing. I've checked all of the obvious things with regard to layers. I've never seen this before, but I'm sure that I will find that the answer is obvious.
    Thanks.
    Using release 2009
    Super Member Murph_map's Avatar
    Murph_map's Computer Details
    XP,Visa, Win7
    HP something or other and the laptop is an HP too
    2 gigs or 6 gigs in Laptop
    Utilities
    Murph_map's Discipline Details
    Boats and campers renting and repairs
    Utilities
    GIS and Map making.
    Map 3D 2011
    Feb 2011
    TN or KY depends if I'm at work or home.
    585
    Don't know if 2009 version has it but check the XDWGFADECTL variable, also Zoom extents with all layers on.
    Murph
    Need a boat or camper for the weekend?
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,131
    Quote Originally Posted by Murph_map View Post
    I think you will find that 2009 does have it. This snip is taken from 2012 OPTIONS>DISPLAY.
    If I am having a hard time finding an XREF in modelspace (against my black background), I will change the VISUAL STYLE to conceptual, which by virtue of the lighter background color often makes it leap right out at me. Or you can try using a 3D perspective, like an isometric angle or two, as the item XREFed may display a larger profile from another perspective.
    After you zoom extents, concentrate your search on the perimeter, which is more than likely where you will find it, or perhaps you will find the name of the XREF, indicating that is has not been found for attachment.
    Senior Member daft vader's Avatar
    MEP 2008
    Jul 2006
    uk
    171
    First thing to check is it wasnt inserted on a layer that is set to off seems to happen a lot here
  5. #5
    Super Member irneb's Avatar
    irneb's Computer Details
    Win7 Pro 64bit
    Antec One Hundred
    ASUS P8P67-Pro P67
    Intel i7 2600 @ 3.4GHz
    16GB-1600MHz
    GeForce GT 430 (1GB)
    Seagate1TB SATA2 - 7200rpm
    Samsung 2333TN 23" 1920 x 1080 Full HD LCD Monitor2GW
    Architectural
    irneb's Discipline Details
    Architectural Technician and Programmer
    Architectural
    AutoCAD 2013
    Sep 2010
    Jo'burg SA
    1,630
    Also, something one of the guys here did which embarrassed him quite a lot: He attached a 2010 version DWG using ACad 2008 and couldn't understand why it wasn't showing up. If you don't have a version of 2010 or later, then download the free DWG TrueView 2012 from AutoDesk. It allows you to convert DWGs to/from numerous versions.
    Other things you might also try:
    • Audit / Recover and purge the DWG you're trying to attach.
    • Does the DWG actually contain any objects? Does it perhaps contain only Overlays? Also only the Model Space of a DWG is attached/overlaid into another - nothing on PS wil be shown.
    • Ensure ALL layers (both the current DWG's as well as the XREF layers) are ON & Thawed.
    • Is the XRef XClipped?
    • Is the XRef listed as loaded in the XRef manager?
    • Is it possible to select the xref object using QSelect / Select All and then using the Properties Palette?
    Knowledge is proportional to experience, but wisdom is inversely proportional to ego!
    My little bit of "wisdom": Hind-sight is useless, unless used to improve the next forethought!
  6. #6
    Architectural
    Project Manager
    Architectural
    AutoCAD 2009
    Sep 2011
    Northeast U.S.A.
    55
    I tried all of the obvious things, most as noted above, and nothing worked. I ended up scraping the whole thing and starting over, and that worked. I always love wasting time on this stuff, but such is life.
    Quote Originally Posted by irneb View Post
    Maybe I'm not reading what you wrote correctly, but I attach modelspace created titlesheets into paperspace as xref's all of the time, and it works fine. I just did one this morning.
    Autocad 2009
    Windows 7
  7. #7
    Win7 Pro 64bit
    Antec One Hundred
    ASUS P8P67-Pro P67
    16GB-1600MHz
    Architectural
    Architectural
    AutoCAD 2013
    Sep 2010
    Jo'burg SA
    1,630
    Quote Originally Posted by wings View Post
    Don't I know it!
    I think we might be on different wave lengths. What I was trying to explain in that line is the following:
    • If a DWG has no linework inside it, but only has Overlays, then attaching it into another will show nothing as overlays won't get nested.
    • If a DWG only contains linework in one or more of its tabs (but nothing in its MS), then attaching it will show nothing.
    I'm with you on the MS-created title block, you can place an xref in Paper Space. I do the same here.
  8. #8
    Architectural
    Project Manager
    Architectural
    AutoCAD 2009
    Sep 2011
    Northeast U.S.A.
    55
    Got it. Yes, that does make sense, and was not the issue yesterday.
    Thanks.
    Autocad 2009
    Windows 7
  9. #9
    Super Member DANIEL's Avatar
    Mechanical
    DANIEL's Discipline Details
    Industrial
    Mechanical
    AutoCAD 2012
    May 2005
    Arlington Texas
    995
    do you have any proxy information, data that was created from another program?
    If you would like to help my 2 year old niece Alaina in her battle against Leukemia you can donate blood at any Carter Blood Care and put SPON050875 on the donor form. Thank you so much for any contributions in this matter that you can make.
    Luminous beings are we, not this crude matter.
  1. Replies: 2
    Last Post: 19th Jul 2010, 06:42 pm
  2. Annotative text in XREF? Xref units mm, parent drawing m
    By spittle in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 3rd Aug 2009, 09:06 am
  3. Parts of Xref does not show
    By MarkCalvert in forum AutoCAD General
    Last Post: 27th Mar 2009, 03:15 pm
  4. contour lines show up when xref inserted
    By corinne in forum AutoCAD Drawing Management & Output
    Last Post: 5th Sep 2008, 05:23 pm
  5. Layer Properties Manager won't show xref layers
    By IvoryEric in forum AutoCAD Drawing Management & Output
    Last Post: 9th May 2007, 05:33 pm
