+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 28 of 28
Thread: Civil Drafting
  1. #21
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,104
    Default
    Don't put any dimensioning. For a quick location point draw a circle with its center point on the grid intersection for the nearest spot elevation you used in your calculations. The point at which the circle intersects the grid (between the two elevations you are working with) is where you insert your block (like the one I suggested). Then you can put your label (text) next to it. I'd instruct you about using attributes with a block but you seem to be struggling at the moment so we will steer clear of that. After you have inserted the block erase the circle. To check a dimension between two objects you can use the DISTANCE command (DI for short) and remember to use your OSnaps to make accurate picks. You are familiar with OSnaps right?
    Not sure about the "0"? In this exercise your new spot elevations should be going on a specific layer (probably called out in your project instructions) and not on layer "0".
  2. #22
    Full Member
    Using
    AutoCAD 2010
    Join Date
    Jul 2011
    Location
    Ellijay, GA.
    Posts
    66
    Default
    Quote Originally Posted by ReMark View Post
    yes, I', familiar with it, I keep working on it.
  3. #23
    Full Member
    Using
    AutoCAD 2010
    Join Date
    Jul 2011
    Location
    Ellijay, GA.
    Posts
    66
    Default
    Quote Originally Posted by bracken2 View Post
    ok I start over, on the part where I put my spot elevation,(xxx) it says to put the 3 x, on the lower-left corner, but my question is do they go on the left side or right, or bottom,
  4. #24
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,104
    Default
    Why don't you find the thread that has the images of this project included in it and take a look.
    Never mind. I found it for you. Personally I don't think it matters where it goes.
    http://www.cadtutor.net/forum/showth...ect-help/page3
  5. #25
    Full Member
    Using
    AutoCAD 2010
    Join Date
    Jul 2011
    Location
    Ellijay, GA.
    Posts
    66
    Default
    here a update on my new drawing,I put the xxx, at the right side of the X
  6. #26
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,104
    Default
    I'm not on my CAD computer at the moment but when I have the opportunity I'll take a look. Did you click on the link to the other thread I posted?
  7. #27
    Full Member
    Using
    AutoCAD 2010
    Join Date
    Jul 2011
    Location
    Ellijay, GA.
    Posts
    66
    Default
    Yes, but they are different, I have been looking at the one you posted
  8. #28
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,104
    Default
    I don't think it's going to matter much. As long as the location of the symbol is correct relative to the grid and as long as you have the correct spot elevation assigned then I think you'll be fine.
Similar Threads
  1. Civil Drafting
    By bracken2 in forum Student Project Questions
    Last Post: 1st Jan 2012, 10:17 pm
  2. Civil Drafting Plate 2
    By wendymoose in forum Student Project Questions
    Last Post: 25th Aug 2011, 08:10 pm
  3. need help with civil drafting
    By Firligic in forum AutoCAD Beginners' Area
    Last Post: 16th Jan 2011, 02:48 am
  4. Civil Drafting Textbook
    By BIGMIKE09281946 in forum AutoCAD Beginners' Area
    Last Post: 7th Sep 2009, 04:10 am
  5. Civil Drafting Standards
    By WannaBeCader in forum AutoCAD Drawing Management & Output
    Last Post: 13th Jan 2006, 03:31 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
