Results 1 to 2 of 2
Thread: No Model Space
    Forum Newbie
    AutoCAD pre 2000
    Jan 2012
    1
    Default No Model Space
    I used an ‘A’ size Standard DWG, exploded it (in paper space)but cannot find any status bar on bottom with model space, paper space buttons etcon this XP PC.
    If I click on VIEW, paper space has a check mark, If I click onmodel space (tiled) my DWG disappears.
    How Can I get an active model space view port and buttons onthe bottom?
    Another problem, I transferred my AutoCad 14 DWG’s from my oldW2K PC onto a flash drive and saved it to my XP PC. Unfortunately they open up as read only.
    If I go to propertiesto the Read Only check box it is already unchecked.
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,131
    Try entering OPTIONS at the commandline, then open the PROFILES tab and choose another user profile and set it current. That may get you your layout back. It sounds like you also need to create a VIEWPORT in your layout. You are on a seriously vintage version of the program, so most of what I suggest may not be available for you. Hopefully one or more of the crusty old guard will remember how they used to work, in the last millenia.
  1. Acad 2010 - Text size changes in model space behave as if in paper space.
    By Trickinitup in forum AutoCAD Drawing Management & Output
    Last Post: 7th Sep 2011, 03:44 am
  2. 2011 AutoCAD - Setting my LTSCALE in Paper Space as the same it is in Model Space
    By Rage221677 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 23rd Dec 2010, 07:31 pm
  3. AcadPViewport2 - Deleting items in model space that aren't seen inside paper space
    By lovemy65stang in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Aug 2009, 05:26 am
  4. Replies: 0
    Last Post: 22nd Jan 2007, 10:20 pm
  5. Convert 3D AutoCAD Model Space Drg to 2D Model Space Drg
    By garycrampton in forum AutoCAD Beginners' Area
    Last Post: 22nd Dec 2005, 10:17 am
