Results 1 to 4 of 4
    Forum Newbie Spacey's Avatar
    Spacey's Computer Details
    Windows 7 Ultimate
    HP Z600 Workstation
    Civil
    Spacey's Discipline Details
    Civil Drafter
    Civil
    earthworks, roads, and drainage aswell as small amounts of mechnical drafting
    Civil 3D 2012
    Dec 2011
    Australia
    6
    Default Section view data
    Hi,
    Another day, another problem, this time about Section views, can anyone tell me if its possible to get your data from an alignment? to clarify the way i percieve it to work is Civil3D obtains its horzontial position (chainage) from the alignment and then the height from the surface you select. Is it possible to get Civil3D to take the height from the alignment rather than a selected surface??
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows XP Pro
    Dell Optiplex 330
    Civil
    CyberAngel's Discipline Details
    Civil Drafter
    Civil
    Civil 3D 2013
    Jul 2006
    Anywhere Else
    976
    If you are talking about cross sections, a surface will give you a line (two dimensions) in a section view, while an alignment will only give you a point (one dimension). In other words, a cross section is cutting a three-dimensional surface along a line to give you a two-dimensional projection. With an alignment, you're starting with a two-dimensional line, so the section would cut that down to one dimension.
    Are you talking about the center point of your assembly? I must be missing something.
    breaking AutoCAD on a regular basis since 1991
    Windows 7 Ultimate
    HP Z600 Workstation
    Civil
    Civil Drafter
    Civil
    Civil 3D 2012
    Dec 2011
    Australia
    6
    not to worry i worked out a work around, i was talk about the profile view, ie, the long section of an alignment, i was trying to do somethng that couldnt be done because i didnt know the system well enough, i thought, for some reason, that alignments could have heights, but i have since worked out they cant.
    Windows XP Pro
    Dell Optiplex 330
    Civil
    Civil Drafter
    Civil
    Civil 3D 2013
    Jul 2006
    Anywhere Else
    976
    If you're talking about a vertical profile, defining your alignment vertically is the whole point. A corridor is what you get when you sweep an assembly along that profile.
  1. Replies: 9
    Last Post: 5th Dec 2011, 07:17 pm
  2. Projected view from a section view
    By Goomba in forum SolidWorks
    Last Post: 27th Oct 2011, 01:28 pm
  3. Section view
    By abishop in forum Autodesk Inventor
    Last Post: 10th Sep 2010, 01:05 pm
  4. export cross section data?
    By javent in forum Civil 3D & LDD
    Last Post: 11th Jun 2010, 03:42 am
  5. Section View ?
    By Jugulate in forum 3D Modelling
    Last Post: 4th Nov 2009, 02:50 am
Tags for this Thread
