jmerch Posted January 24, 2012 Share Posted January 24, 2012 I'd like to get rid of all AEC block names in my template. I've tried BLDSYSPURGE and that didn't work. We don't currently use ACAD MEP for it's intended purpose so I just want these out of the block name list in our template for now. Is there a way to do so? Quote Link to comment Share on other sites More sharing options...
tzframpton Posted January 24, 2012 Share Posted January 24, 2012 No, you can't. Well, you can if you're a programmer and can access all the hidden AEC Elements that aren't available via the OOTB purging objects. Best thing to do is swap out your Startup and QNEW templates with a standard AutoCAD Template. You can access this from the vanilla AutoCAD profile. Make all the adjustments you need and save as DWT, this is what I do. In fact there might be a bad-ace purging program floating around... I think I saw one over at TheSwamp.org that got beneath the surface, but it only went so far. Quote Link to comment Share on other sites More sharing options...
jmerch Posted January 24, 2012 Author Share Posted January 24, 2012 Found it. Tried AECTOACAD and started a new template. This got ride of them. Thanks Tannar! Quote Link to comment Share on other sites More sharing options...
tzframpton Posted January 24, 2012 Share Posted January 24, 2012 Ah, forgot about the export to AutoCAD command, yeah that does it too. Forgot to think outside the box today, lol. Jeff H over at TheSwamp.org showed me the AEC Template in his Programming IDE and there's all kinds of crap you can't access, it's crazy. Quote Link to comment Share on other sites More sharing options...
jmerch Posted January 24, 2012 Author Share Posted January 24, 2012 Forgot to think outside the box today, lol. Are we.....are we allowed to do that? lol Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 25, 2012 Share Posted January 25, 2012 Acad 2012 has some extra purge tools re AEC objects, pretty sure seen it metioned that you can start Autocad with a dwg called . which is totally blank our smallest dwt is 80k Someone may have a dxf that will equal a dwg with absolute minimum of info. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted January 25, 2012 Share Posted January 25, 2012 Also, the command AECOBJEXPLODE will do it without the need to create another file. I use these settings. You may need to select "All Layouts". Quote Link to comment Share on other sites More sharing options...
