Results 1 to 5 of 5
    Senior Member
    AutoCAD 2010
    Jan 2010
    121
    Default How to change color field box?
    Hi everyone,
    I'm using a lot's of field in my plan and i want like to know if it's possible to change de color grey of the field box? Without color would be best for me!
    Many thanks,
    Bono
    AutoCAD 2013
    Nov 2011
    6,045
    You can uncheck DISPLAY BACKGROUND OF FIELDS in your OPTIONS, as shown in the attachment.
    If you have never looked at, or set them before you might want to look at the field update settings options.
    Senior Member
    AutoCAD 2010
    Jan 2010
    121
    Many Thanks Dadgad!!!!!
    And change is color it's possible?
    AutoCAD 2013
    Nov 2011
    6,045
    Quote Originally Posted by bono05 View Post
    I don't believe that you can change the display COLOR of the field. Perhaps with Lisp you could, but I see no way to do it from the regular autocad commands and options.
    However, you can specify TEXT HIGHLIGHT COLOR, by clicking into a field and using the right click shortcut menu. After having done that, should you opt to CONVERT FIELD TO TEXT, also in the right click shortcut menu, then the assigned Text Highlight Color will become the fill color in the background of the text, but only during editing. The field will revert to transparent (colorless) when you finish the edit.
    If all you are looking for is a mask behind the contents, and it doesn't need to be a field, then try the EXPRESS tool TEXT MASK, where you could set numerous options, including color.
  5. #5
    Senior Member
    AutoCAD 2010
    Jan 2010
    121
    Great, thanks for answer dadgad.
  1. Trying to change the Color of the sky
    By Bowl.Spliffson in forum AutoCAD 3D Modelling & Rendering
    Last Post: 26th Mar 2015, 06:20 pm
  2. couldn't change the line weight of resistors, or change their color
    By jackson6612 in forum AutoCAD Beginners' Area
    Last Post: 13th Jan 2011, 12:10 pm
  3. Lisp to change all objects with a certain color to another color
    By mikeSIEMENS in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Jan 2010, 04:59 pm
  4. When I change the color the dimensions change!
    By Mark Costantino in forum AutoCAD Drawing Management & Output
    Last Post: 12th Oct 2009, 05:55 pm
  5. Change a text field value on 1400 Dwg files
    By snip in forum AutoCAD Drawing Management & Output
    Last Post: 12th Jan 2006, 04:08 am
