cios106 Posted January 27, 2012 Share Posted January 27, 2012 hey guys, i have a dwg file, it has so many x-refs. And x-refs has so many dynamic blocks. As you know there is a frame around the dynamic block objets. But i have many many rectangles-frames that i want to remove.. I thought that if i set it's colour to black, i could ged rid off to see this ridiculously big frames. But i couldn't. So what is your suggestions please, thanks all. Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted January 27, 2012 Share Posted January 27, 2012 I don't understand what you mean about the dynamic block having a frame. Could you post a file or a screen shot of what you are seeing? Quote Link to comment Share on other sites More sharing options...
resullins Posted January 27, 2012 Share Posted January 27, 2012 I've never seen that either. Posting a file would help a lot. Quote Link to comment Share on other sites More sharing options...
rkent Posted January 27, 2012 Share Posted January 27, 2012 Post a drawing with a dynamic block showing this behaviour. Quote Link to comment Share on other sites More sharing options...
cios106 Posted January 28, 2012 Author Share Posted January 28, 2012 check out the attachment, sorry i should have do this first, thanks a lot guys. dynamic object frames.dwg Quote Link to comment Share on other sites More sharing options...
cios106 Posted January 28, 2012 Author Share Posted January 28, 2012 command is FRAME. and make your selection to hide frames between 0-2. Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted January 30, 2012 Share Posted January 30, 2012 You must have an image of some sort incorporated into your dynamic block. Dynamic blocks don't have frames. Quote Link to comment Share on other sites More sharing options...
JJuarez Posted August 1, 2012 Share Posted August 1, 2012 Has anyone found out how to get rid of these frames? I have the same issue and it makes my autocad run slow. I actually had to go back to using release 10 to be able to manage file. Any help would be greatful. Thanks Quote Link to comment Share on other sites More sharing options...
resullins Posted August 1, 2012 Share Posted August 1, 2012 Yes, Cios was right. Enter the command FRAME, and set the system variable to something else. 0 if you want them gone all together. Quote Link to comment Share on other sites More sharing options...
JJuarez Posted August 1, 2012 Share Posted August 1, 2012 resullins...thanks for your quick reply. I have set "Frame" to "0" and it does make the frames go away. Question 1? I have other dynamic block named the same but frame do not show up when "Frame" is set to "1", any reason for this? Question 2? Does this frame issue "on" or "off" make system run faster or slower? Quote Link to comment Share on other sites More sharing options...
resullins Posted August 1, 2012 Share Posted August 1, 2012 Then it may not be a frame. Can you post the file? Quote Link to comment Share on other sites More sharing options...
JJuarez Posted August 1, 2012 Share Posted August 1, 2012 I can.....if you can instruct me on how to put it one here? Have never posted files. Thanks Quote Link to comment Share on other sites More sharing options...
resullins Posted August 1, 2012 Share Posted August 1, 2012 Click the button below the response window that says "Go Advanced", then scroll down until you see a button that says Manage Attachments. You'll get a little pop-up, and go from there. Let me know if you have any other questions. Quote Link to comment Share on other sites More sharing options...
JJuarez Posted August 1, 2012 Share Posted August 1, 2012 resullins, I have followed instructions. It took me to another website "informationgetter" is this correct? If so, which selection do I make? Sorry, never done this before. Quote Link to comment Share on other sites More sharing options...
JJuarez Posted August 1, 2012 Share Posted August 1, 2012 I have tried to upload but it keeps telling me the file is to big for uploading. I have deleted everything from file execpt 4 dynamic blocks. The file size is 1.34mb. Are the dynamic blocks making this file that large? Do all dynamic blocks make files that large? Thanks Quote Link to comment Share on other sites More sharing options...
resullins Posted August 1, 2012 Share Posted August 1, 2012 No. Have you tried purging the drawing? Quote Link to comment Share on other sites More sharing options...
JJuarez Posted August 1, 2012 Share Posted August 1, 2012 Yes..the file has been purged. Quote Link to comment Share on other sites More sharing options...
JJuarez Posted August 1, 2012 Share Posted August 1, 2012 In investigating this problem with dynamic block. I have opened this test file in both Autocad 2010 and 2012. With the option "Frame" = 0, Doing zoom extents, 2010 zooms in to my 4 dymamic blocks, 2012 zooms out to where the outer border of the frame is. Any perticaular reason? Quote Link to comment Share on other sites More sharing options...
resullins Posted August 1, 2012 Share Posted August 1, 2012 Check your PMs. I just sent you my email. Quote Link to comment Share on other sites More sharing options...
JJuarez Posted August 1, 2012 Share Posted August 1, 2012 Replied to your email. Thanks Quote Link to comment Share on other sites More sharing options...
