Page 3 of 3 FirstFirst 1 2 3
Results 21 to 24 of 24
Thread: steel shapes
  1. #21
    Forum Newbie JoshBero's Avatar
    Mechanical 2012
    May 2012
    3
    Quote Originally Posted by StykFacE View Post
    Al's Steel Mill is a great add-on to vanilla AutoCAD and has been floating around for years.
    http://cadtips.cadalyst.com/standard...ypes-and-sizes
    Also, all Autodesk "vertical products" have an extensive steel library that comes standard, with great functionality since they are "AEC Objects".
    Thank you for the info. Our company recently purchased several AutoCAD LT licenses and we have everybody bugging the one guy with Mechanical to export shapes for them.
    I am having trouble finding where to download this Al's Steel Mill from the link you provided (or a Google search).
  2. #22
    Junior Member
    AutoCAD 2014
    Dec 2008
    12
    I've never had an issue in the past download and using Al's Steel Mill program, but not having much luck on my new work PC that has Autocad 2018 on it. I downloaded the TIP1779.zip file from link provided above and extracted it. Opened Autocad 2018, Appload and browsed to the location of the extracted file. Then went to Options and added the folder to the support files in autocad.
    When I try to run it (type STL) I get the follow error:
    Error in dialog file
    "C:\Users\Downloads\TIP1779\stl.dcl", line 3:
    warning: redefining object.
    Symbol: "stl".
    Thoughts?
    Thanks
    Russ
    Autocad 2018
  3. #23
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    Works just fine here on AutoCAD 2018. Did you read the Help file I mentioned earlier? Are you sure that is the correct path? I load mine through my ACADDOC.LSP.
    Code:
    (load "STL.lsp" "STL.lsp Failed to Load.")
  4. #24
    Junior Member
    AutoCAD 2014
    Dec 2008
    12
    so I actually reset all settings to default and tried it again, and it worked fine strangely enough.
    Thanks for you help tho. Much appreciated.
  1. Steel Shapes
    By Lemmesee in forum AutoCAD General
    Last Post: 6th Nov 2014, 07:06 pm
  2. Mechanical BOM partslist with steel shapes
    By JoeC in forum Mechanical & MDT
    Last Post: 6th Mar 2012, 07:30 am
  3. steel shapes. (sections)
    By IdoBrickner in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Apr 2011, 04:22 am
  4. Steel shapes
    By bolton78 in forum AutoCAD General
    Last Post: 3rd Jun 2008, 02:38 pm
  5. Structural steel shapes and dimensions catalog.
    By b.muqlueen in forum AutoCAD Drawing Management & Output
    Last Post: 8th Feb 2008, 05:26 pm
