+ Reply to Thread
Results 1 to 9 of 9
  1. #1
    Full Member
    Discipline
    Manufacture
    BrianTFC's Discipline Details
    Occupation
    Structral Detailer
    Discipline
    Manufacture
    Using
    Mechanical 2013
    Join Date
    Jan 2012
    Location
    Indiana
    Posts
    95
    Default Change chamfer results to the current layer?
    Hi All
    Does any one have a Lisp routine to turn the diagonal line that chamfer creates to the current layer instead of the original layer of the lines? I would appreciate any help.
    Thanks
    Brian
  2. #2
    Luminous Being alanjt's Avatar
    Using
    Civil 3D 2011
    Join Date
    Apr 2008
    Posts
    5,988
    Default
    Is your stated version (2000i) an older LT version? Is it LISP capable?
    DropBox | finding the light...
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
  3. #3
    Full Member
    Discipline
    Manufacture
    Occupation
    Structral Detailer
    Discipline
    Manufacture
    Using
    Mechanical 2013
    Join Date
    Jan 2012
    Location
    Indiana
    Posts
    95
    Default
    We use 2000i and 2012
  4. #4
    Using
    Civil 3D 2011
    Join Date
    Apr 2008
    Posts
    5,988
    Default
    Code:
    (defun c:Chamfer2 (/ ent)
      (setq ent (entlast))
      (command "_.chamfer")
      (while (eq (logand 1 (getvar 'CMDACTIVE)) 1) (command PAUSE))
      (if (not (equal ent (setq ent (entlast))))
        (entmod (list (cons 8 (getvar 'CLAYER)) (cons -1 ent)))
  5. #5
    Full Member
    Discipline
    Manufacture
    Occupation
    Structral Detailer
    Discipline
    Manufacture
    Using
    Mechanical 2013
    Join Date
    Jan 2012
    Location
    Indiana
    Posts
    95
    Default
    Thanks that is exactly what i was looking for...
  6. #6
    Using
    Civil 3D 2011
    Join Date
    Apr 2008
    Posts
    5,988
    Default
    You're welcome.
  7. #7
    Senior Member Ahankhah's Avatar
    Computer Details
    Ahankhah's Computer Details
    Operating System:
    Windows XP
    Using
    AutoCAD 2012
    Join Date
    Jun 2010
    Location
    Tehran, Iran
    Posts
    430
    Default
    But when chamfering a Polyline object while Trimmode variable is set to zero, there may be more than one object as the result of CHAMFER.
    For this case alanjt's nice code can be edited to:
    Code:
     (while (setq ent (entnext ent))
    Mehrdad Ahankhah مهرداد آهن خواه
    www.IranCAD.com
  8. #8
    Quantum Mechanic Lee Mac's Avatar
    Computer Details
    Lee Mac's Computer Details
    Operating System:
    Windows 7 Ultimate (32-bit)
    Discipline
    Multi-disciplinary
    Lee Mac's Discipline Details
    Discipline
    Multi-disciplinary
    Details
    Custom Programming / Software Customisation
    Using
    AutoCAD 2013
    Join Date
    Aug 2008
    Location
    London, England
    Posts
    15,708
    Default
    Be careful when 'entlast' is an Attribute Block or Polyline.
    Lee Mac Programming
    With Mathematics there is the possibility of perfect rigour, so why settle for less?
    Just another Swamper
  9. #9
    Computer Details
    Operating System:
    Windows XP
    Using
    AutoCAD 2012
    Join Date
    Jun 2010
    Location
    Tehran, Iran
    Posts
    430
    Default
    Quote Originally Posted by Lee Mac View Post
    I checked Polyline and it doesn't cause any error on VERTEX and SEQUEND objects, but changes ATTRIB objects. So the code can be edited to this one:
    Code:
      (or
       (member (cdr (assoc 0 (entget ent))) '("ATTRIB" "VERTEX" "SEQUEND"))
    www.IranCAD.com
Similar Threads
  1. Change current layer and selection set to layer 0..
    By hardwired in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Jan 2011, 02:14 pm
  2. chamfer command giving two different results
    By gargoyle27 in forum Autodesk Inventor
    Last Post: 21st Oct 2010, 04:27 pm
  3. current layer change
    By hokie555 in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Oct 2009, 09:40 pm
  4. AUGI Board of Directors Election Results - No Change
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 29th Dec 2008, 07:00 pm
  5. Change the angle in a chamfer (3d cylinder)
    By ShawnPeter in forum AutoCAD 3D Modelling & Rendering
    Last Post: 30th Jan 2008, 11:19 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
