mpuchtel Posted January 31, 2012 Share Posted January 31, 2012 Hi, long time AutoCAD user here, but I just upgraded to 2011 and am having a hard time replicating some previous functionality. Specifically, I frequently have a line and want to stretch its length by some amount. In the past I would highlight the line, snap my cursor to the endpoint, click, and begin dragging. While dragging, I would type the distance to stretch and it would do exactly that. Now, my typed value seems to be assigned to the global length of the line, rather than the relative stretched value. I'm sure there is a simply way to change this setting, but after an hour trying to figure it out I figured I'd post! Thanks in advance. Max Quote Link to comment Share on other sites More sharing options...
mpuchtel Posted February 7, 2012 Author Share Posted February 7, 2012 So, 98 views and no responses? Is there something I can clarify? Quote Link to comment Share on other sites More sharing options...
Tiger Posted February 7, 2012 Share Posted February 7, 2012 Are you using Dynamic input? You can then use tab to switch what value you are inputting. Quote Link to comment Share on other sites More sharing options...
rkent Posted February 7, 2012 Share Posted February 7, 2012 Try changing DYNDIGRIP to 2. or... Right click on the DYN button at the bottom of the screen, pick settings, dimension input settings, uncheck resulting dimension, check length change. Quote Link to comment Share on other sites More sharing options...
mpuchtel Posted February 7, 2012 Author Share Posted February 7, 2012 rkent - thanks for pointing me to that settings area! Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 7, 2012 Share Posted February 7, 2012 @rk: Is there a way to enable the angle/length display when stretching but NOT when drawing an object? Quote Link to comment Share on other sites More sharing options...
rkent Posted February 7, 2012 Share Posted February 7, 2012 With DYNMODE on (1, 2, or 3), holding F12 is a temporary override key (which can be assigned to other more convenient keys). Other than that I don't know. Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 7, 2012 Share Posted February 7, 2012 With DYNMODE on (1, 2, or 3), holding F12 is a temporary override key (which can be assigned to other more convenient keys). Other than that I don't know. 1 is almost perfect. It is an improvement. I like seeing everything when I grip edit, but not when I'm just drawing. Thanks. Quote Link to comment Share on other sites More sharing options...
