Results 1 to 2 of 2
    Forum Newbie
    3ds Max 2012
    Feb 2012
    1
    Exclamation 3DS viewport object display error
    Cannot change the colour of object in view port. It appears black with only the edges of the object taking on the chosen colour (pink) I haven't applied a material map to it and i don't wish to at this stage.
    Things I have tried:
    Using edit normals under editable mesh and flipping them and unify.
    Applying a different colour.
    Checking backface cull box in object properties.
    Weld vertices modifier.
    any help would be most appreciated.
    Warning; File is from a student version.
    Last edited by SamAttack; 1st Feb 2012 at 04:06 pm. Reason: file uploaded was from a student version of 3ds
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    3ds Max 2011
    Feb 2006
    Southern California
    8,489
    Sorry, I didn't see this thread until now.
    The first thing you need to do is select your object, right click and choose "Convert to Editable Poly". This will break the object up into individual parts.
    What I found out is that your objects have a default material applied to them, (Autodesk Generic), which is why you can't change the color. Was this model created in another program and then imported into Max?
    If you want to change the color of the objects you will need to do so through the Material Editor.
    "Work Smart, Not Hard"
    Click to View My Portfolio ( Updated 05/21/2013 ) --->
    http://www.rdeweese.com/
  1. error: Automation Error. Object was open for read
    By muthu123 in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Jul 2010, 12:33 pm
  2. Paperspace layout/viewport display in B&W?
    By CalypsoArt in forum AutoCAD General
    Last Post: 10th Jun 2010, 01:32 pm
  3. Image Won't Display in Viewport
    By wannabe in forum AutoCAD Drawing Management & Output
    Last Post: 18th Apr 2009, 02:58 am
  4. viewport on display locked
    By rthoonsen in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Oct 2007, 06:57 am
  5. VIEWPORT LAYER DISPLAY CONTROL
    By muirarchitects in forum AutoCAD Drawing Management & Output
    Last Post: 9th Jun 2006, 06:09 pm
