- "Select" block
- "Right-Click", Select "Select Similar"
- Press "Delete"
Greetings
How to write short lisp to erase all insertions of one unique block?
or how to do same from command line?
i.e.
(command "._erase" <blockname> "")
but this doesn't work.... somewhere there must be a place for a dotted pair?
TIA
Steve
- "Select" block
- Press "Delete"
"Potential has a shelf life." - Margaret Atwood
Separately, the ERASE command is expecting a selection set.
Code:(defun c:FOO (/ ss) (if (setq ss (ssget ":S:E:L" '((0 . "INSERT")))) (command "._erase" (ssget "_x" (list '(0 . "INSERT") (cons 2 (cdr (assoc 2 (entget (ssname ss 0))))) (cons 410 (getvar 'ctab)))) "") (prompt "\n** Nothing selected ** ")) (princ))
Quickly written:
Code:(defun c:DelBlock ( / blk ent inc obj sel ) (while (not (or (eq "" (setq blk (getstring t "\nSpecify Block Name: "))) (tblsearch "BLOCK" blk) ) ) (princ "\nBlock not Found.") ) (if (and (not (eq "" blk)) (setq sel (ssget "_X" (list '(0 . "INSERT") (cons 2 (strcat "`*U*," blk))))) ) (repeat (setq inc (sslength sel)) (setq ent (ssname sel (setq inc (1- inc))) obj (vlax-ename->vla-object ent) ) (if (or (and (vlax-property-available-p obj 'effectivename) (eq (strcase blk) (strcase (vla-get-effectivename obj))) ) (eq (strcase blk) (strcase (vla-get-name obj)) ) ) (entdel ent) ) ) ) (princ) ) (vl-load-com) (princ)
Lee Mac Programming
Just another Swamper
Thank you Lee and RM... I now have the tools to complete my task !!! guys here are the best of the NET !!!
cheers and beers around !!
Steve
You're welcome Steve![]()
Lee Mac Programming
